O2 Sensors Question
Discussion in '1st Gen Tundras (2000-2006)' started by DesertRoads, Jul 17, 2023.
  1. Jul 17, 2023 at 12:55 PM
    DesertRoads
    DesertRoads [OP] Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    I was trying to sell my 2005 Tundra and the last person to test drove it kept turning the truck on and off and eventually triggered a check engine light. Grrr. So I plugged in my OBDII reader and it said P2238 "O2 Sensor Positive Current Control Circuit Low Bank 1 Sensor 1". So... I'm guessing that by doing the off and on it helped a teetering O2 sensor meet it's fate?
    Is this something I need to replace all 4 sensors, as they are all going bad? Or....? Any direction would be greatly appreciated. Thank you!
  2. Jul 17, 2023 at 1:03 PM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    Replace the failed one and sell it.
  3. Jul 17, 2023 at 1:42 PM
    shifty` Bohannon Bohannon Bohannon Bohannon
    Before jumping to replace anything, try resetting the code and drive it around. This could just be a fluke, with this specific code at least.
    If the code returns in 25-30 miles, it's fingering the driver side sensor between the exhaust manifold and cat (upstream). I usually recommend replacing O2 sensors in pairs, i.e. if you're doing the one pre-cat, to the one post-cat on the same side. Buy Denso parts on this one.
    metalpete and bfunke like this.
  4. Jul 17, 2023 at 2:03 PM
    DesertRoads
    Utah's West Desert
    Thank you for your insight. The check engine light did go away. I will see if it returns, if so I will replace the O2 sensors in pairs.
  5. Jul 17, 2023 at 2:22 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Idiot test drivers. I sold my 4Runner before moving to Japan and the dude who test drove it decided to put it in 4WD and do circles/doughnuts on hard pavement. When he returned he said “hey dude - something wrong with your 4 wheel drive” left quickly. Had to fix one of my hubs. F’ing a$$hats.
  6. Jul 17, 2023 at 2:40 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    I don't know if the sensors are in the exact same location as my 2001, but the upper/driver (bank 1 sensor 1) isn't too bad to do and can be done from underneath. However, the upper/passenger was a total bitch, you need to reach behind the engine from above to disconnect the harness.
    Lower sensors aren't too bad, can be a pain if the nuts are old and rusted...but at least they are easily accessed.
