O2 sensor question
Discussion in '1st Gen Tundras (2000-2006)' started by 20Tundra04, Apr 5, 2020.
  1. Apr 5, 2020 at 3:59 PM
    20Tundra04
    20Tundra04 [OP] New Member
    2004 Tundra TRD
    Hi - my 04 Tundra started making some noise today like there was an exhaust leak right under my drivers seat all of a sudden. Check engine light is on too.
    Taking a look, the O2 sensor behind the catalytic converter has a rotted gasket, and more alarmingly, no nuts on the two bolts that holds the sensor and guard in place, which was allowing for the exhaust to escape and resulting in the noise and (I'm assuming) the check engine light.
    Assuming the sensor might need replaced judging by the wiring there, but I need to replace the gasket and nuts as well obviously.
    Can anyone tell me the part numbers for the sensor and gasket, and tell me what size bolts those are? Seems like an easy enough fix but I want to make sure I get the right parts online.
    Thanks!
    MrAristo likes this.
  2. Apr 5, 2020 at 4:10 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    What is the code#?
  3. Apr 5, 2020 at 4:15 PM
    20Tundra04
    2004 Tundra TRD
    Dunno - haven't been to get it scanned
  4. Apr 5, 2020 at 4:33 PM
    Johnsonman
    Austin
    Sequoia
  5. Apr 6, 2020 at 4:16 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Zooming in shows it to be a Denso 89465-0C120 which is what I used recently when changing mine on a 2004. I bought mine from local yokel Napa dealer which came with gaskets. Given one of the nuts was messed upped, I chose to also buy a pkg of exhaust nuts that also came with studs. Should be able to purchase at any auto type parts store....Napa, Autozone, Adavance Auto etc.
    FrenchToasty likes this.
  6. Apr 6, 2020 at 4:32 AM
    koditten
    Kirk
    Midland of the Mitten
    Why does that matter?
    With any exhaust leak you are getting a code.
    New gasket, new nuts and reassemble. If you get on this right away you won't need to buy a new O2 sensor.
  7. Apr 6, 2020 at 4:35 AM
    20Tundra04
    2004 Tundra TRD
    My thoughts too.... Had to order parts but they will be in on Thursday. We'll see how it goes. The studs are rusted, but I'm hoping the nuts will still fit on correctly since it doesn't look like you can just buy the flange with the studs without also having to weld it on (there is a place online that sells this as a "kit" but I don't have the equipment to do it that way).
    koditten[QUOTED] likes this.
  8. Apr 6, 2020 at 4:42 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    I have a 2002 tundra.i have replaced mine. Write down that number for a comparison, go to the denso website and look it up and compare numbers. Also you can call them for technical help, they are very helpful and will advise your. Hope this helps
    20Tundra04[OP] likes this.
  9. Apr 6, 2020 at 4:55 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Ah man you lost your nuts..........how's that happen. O2 might not be bad, but since your there I would put a new one in, should come with gasket. Spray the studs with some PB blaster and wire brush the threads and see if you get some new nuts on there. Common metric size, 6mm or 8mm, hard to tell from pick. Hopefully you can, if not, might have to run a Die over them. Good Luck.
  10. Apr 6, 2020 at 5:11 AM
    20Tundra04
    2004 Tundra TRD
    I did find a reference suggesting these were 1.25 x 8mm so we'll see how that goes! Thanks!
  11. Apr 6, 2020 at 5:17 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Sounds about right, factory nuts would use a 12mm socket aftermarket might be 13mm socket........6mm nuts would take a 10mm socket.
  12. Apr 6, 2020 at 5:54 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You can always take the new ones to Napa and get a rethreading die to chase the threads.
  13. Apr 6, 2020 at 6:56 AM
    TCMiTundra
    TCMiTundra New Member
    Dave
    2006 Tundra DC SR5
    None, really. Just tires and wheels.
    Somebody mentioned OBDII scanners earlier. I wanted to throw out BlueDriver (www.bluedriver.com ) as an option. I bought one last December and the things are pretty great, especially for $99. They also handle ABS/SRS codes.
    revtune likes this.
  14. Apr 6, 2020 at 7:37 AM
    koditten
    Kirk
    Code readers are really stepping up their game. Lots of power for decent prices now days.
    Anyone that wants to maintain their own vehicle should have one.
    revtune likes this.
  15. Apr 8, 2020 at 11:38 AM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
  16. Apr 8, 2020 at 11:26 PM
    TCMiTundra
    Dave
    2006 Tundra DC SR5
    Truthfully, I was expecting the entire thread to be in all caps. ...and I was actually mildly disappointed that it wasn't :eek:
  17. Apr 25, 2020 at 9:15 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @20Tundra04 Did you ever get this fixed corrrectly?
    I had a similar issue to yours. Although I think yours is the V8 model so our exhaust systems are a little different. I actually sacrificed the heat shield so I could see what i was doing. This did not fix my error code though.
  18. Apr 25, 2020 at 9:37 PM
    04 Tundra
    Albert
    Yeah I got it fixed! So I swapped the rear 02 sensors to see if the code would switch side which it did. So for you if it's an o2 sensor it would go to p0430 now.
    I put a new sensor in and all good.
  19. Apr 25, 2020 at 9:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That might work if I had two downstream sensors like I'm thinking yours has from what I've read, but I'm not a 100%. My exhaust comes from the engine and it joins into one pipe on the passenger side, There's the sensor above the cat, then there's the cat, and then there's the 02 sensor which is the one I had to do the repair on.
  20. Apr 25, 2020 at 9:49 PM
    04 Tundra
    Albert
    Did you clear your code and did it come back ? Or everything's okay now ? If not are you able to swap the 02 sensor front to back?
  21. Apr 25, 2020 at 9:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Cleared the codes, and returned. I did not swap them because I thought upstream, and down stream were different.
    I think Denso has two different part numbers for them. I am not 100% on this.
  22. Apr 25, 2020 at 9:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  23. Apr 25, 2020 at 10:06 PM
    04 Tundra
    Albert
    I hope it's not your catalytic converter. Do you have exhaust leaks near the o2 sensor ? You could be getting fresh air coming in and throwing a code. Leaking manifold ? You could try one more quick fix before pulling the trigger on a new cat .
    SEAFOAM
    https://youtu.be/azpIa_sz9XU
    Hopefully you catalytic converter is not clogged up. You can always try seafoam
  24. Apr 25, 2020 at 10:21 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hell, I might just try that tomorrow. Unless someone else chimes in saying this is a No-No. This has eluded me for years. Guess this is a cheap way to see if I have leaks also like his appears to in front of the rear tire?
    His engine bay needs a good pressure washing, YUCK!
  25. Apr 25, 2020 at 11:46 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    What repair did you have done and what was the engine code?
    That guy doing to seafoam didnt fix a thing with it. He didn't even know what the problem was, disconnecting the battery will clear the code temporarily. Bet that light came back the next day.
  26. Apr 25, 2020 at 11:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    P0420 is the code I have been struggling for years on. I have tried replacing both upstream, and down stream sensors. I've poked around the engine bay a few times. Nothing stood out to me as obviously wrong.
  27. Apr 26, 2020 at 12:11 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Which sensor did you replace? You mentioned only seeing one downstream sensor. You should have 2, you have 2 cats and each has a before and after sensor.
    When you replace a sensor go with Denso, these trucks don't always like Bosch or other sensors for some reason.
    Tundra2 likes this.
  28. Apr 26, 2020 at 12:26 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The one I quoted was downstream.
    I'm pretty sure the V6 only has 2 sensors. One before the 1st cat, and one after the 2nd cat before muffler. Both sensors I am aware of are denso now. The upstream was some bastard brand I'd never even heard of when I replaced it. I'm sure it was some cheap knock off that someone had put on.
    ^^^ This is a Tacoma, but thats basically what my downstream looks like.
  29. Apr 26, 2020 at 1:11 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Check the other side. On the drivers side crawl under the truck and look around. If you have 2 cats then you'll have 4 sensors, otherwise they'd never be able to tell if the driver side cat was working.
  30. Apr 26, 2020 at 4:11 AM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    @Tundra2 @04 Tundra
    Thought I’d chime in. I recently replaced all my 4 of o2 sensors, Bank 1 (driver side) & Bank 2 (passenger side) and Sensor 1s (upstream/front of cats) & Sensor 2s (downstream/behind the cats). I started by replacing both upstreams and only the downstream for bank 2, per my codes. All codes cleared then I got P0420 a day later, meaning a few diff things. Could’ve been bad cat, bad bank 1 sensor 2, or what have you. So I went and got that sensor, made sure my electrical connectors were fine, tightened all my sensors some more, and put in that last sensor. Code never showed itself since.
