O2 sensor faults
Discussion in 'New Member Introductions' started by Islander, Feb 2, 2021.
  1. Feb 2, 2021 at 9:13 AM
    Islander
    Islander [OP] New Member
    2008 white crewmax
    I have a 2008 CM Ted 5.7 with 275 K km. I am experiencing engine fault codes related to the O2 sensors. Local toyota dealer and two other shops said it was the right bank cat. So they changed the upstream cat and sensors on the rht side. No difference! Went 40 km engine fault code lit again. Reset it and it lit again after 50km. I bought a OBD II it tells me that both sides are sending fault codes. Any ideas would be helpful!
    YardBird likes this.
  2. Feb 2, 2021 at 10:19 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Everyone on here wants to know which specific CELs are being set and/or pending.
  3. Feb 2, 2021 at 10:27 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Your cat is probably gone.... if after the oxygen sensor replacement didn't resolve it, then the cat is gone... my car did the same, p0420, replaced the O2 sensor and it would come back after certain amount of miles....the miles kept decreasing after each reset until it wouldn't trigger a ready and I failed the smog test which led me to replacing the cat and it solved my issues..
  4. Feb 2, 2021 at 11:46 AM
    Islander
    2008 white crewmax
    The OBD says the 1 bank 1 sensor four times then it's 02 sensor 1 bank 2 sensor twice, then o2 - .. 2 bank 1 sensor.. i replaced the rht Passenger side cat 4 days ago and got two fails.My OBD didn't give the codes, like a regular code reader would.
  5. Feb 2, 2021 at 11:52 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  6. Feb 2, 2021 at 2:29 PM
    blackdemon_tt
    Bank 1 is the driver side.. if I'm not wrong... you replaced the wrong sensor.. again if I'm not mistaken. Bank 1 sensor 1 is driver side pre cat.
  7. Feb 2, 2021 at 2:31 PM
    blackdemon_tt
    My phone went rogue and posted.... anyway take it to an auto store and use their obd2 system and grab codes..
  8. Feb 2, 2021 at 2:35 PM
    Islander
    2008 white crewmax
    I suppose replacing the upstream on the drivers ( left) might correct some of the faults... I'll find out tomorrow when that happens! It's $600 to find out. Hopefully that's the end of it.
  9. Feb 2, 2021 at 2:37 PM
    Islander
    2008 white crewmax
    The muffler shop has a code reader, I'll see if they confirm the codes before replacing the cat
  10. Feb 2, 2021 at 2:40 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Swap sensors between banks.
    If the faults go to bank 2, it's a sensor issue.
    If faults stay in bank 1 its wiring, bank specific, cat, etc.
  11. Feb 2, 2021 at 2:44 PM
    Islander
    2008 white crewmax
    The codes for bank 2 stopped and bank 1 started, so I'm thinking both upstream cats were toast..
  12. Feb 2, 2021 at 2:58 PM
    Islander
    2008 white crewmax
    I'll get them to try that first.. that's a good idea. Thanks!
  13. Feb 2, 2021 at 3:24 PM
    blackdemon_tt
    Sounds more like a sensor from your response
  14. Feb 2, 2021 at 5:39 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  15. Feb 2, 2021 at 6:33 PM
    Islander
    2008 white crewmax
    Nice to hear from a fellow West coaster, thanks!
  16. Feb 3, 2021 at 2:40 PM
    Islander
    2008 white crewmax
    So in conclusion (I hope) the 1 bank cat was reduced to an expansion chamber! There was just the outer pipe, no insides. Replaced, so both upstream cats replaced. I trust this will be end if the engine service light being lit. Thanks for all suggestions, everything helps.
  17. Feb 3, 2021 at 3:33 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Stick around after you get this figured out and this site will help you spend a lot more on your Tundra!
  18. Feb 3, 2021 at 4:25 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    10+ extra hp for a straight pipe exhaust. Some people would call that a desirable feature.
    Welcome.
  19. Feb 3, 2021 at 8:42 PM
    Islander
    2008 white crewmax
    LA I spent a month inbetween NOLA and Jackson. Quite different from what I'm used to. Had a great time.
    Bakershack likes this.
  20. Feb 3, 2021 at 8:44 PM
    Islander
    2008 white crewmax
    Hadn't thought of straight exhaust pipes, for 10 up sounds like a good tip.. Thanks!
    Jack McCarthy likes this.
  21. Feb 5, 2021 at 8:49 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
  22. Feb 5, 2021 at 3:08 PM
    Islander
    2008 white crewmax
    Thanks for the welcome! I live on east coast of Vancouver Island. West Coast weather is wet! But it beats ice and snow!
