NSV Lightbar installed now power adjusting headlight motor not working
Discussion in 'Electrical' started by FlipMonkey21, Aug 5, 2021.
  1. Aug 5, 2021 at 9:44 AM
    FlipMonkey21
    FlipMonkey21 [OP] New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    I installed the lightbar following the video instruction from HR. I cut the bluewire as suggested also did the following for the NSV patch harness de-pin the blue wire and white wire and place the blue wire in the middle and white wire outside and resolved my signal light hyperflashing issue
    http://5129608.shop.netsuite.com/c....nt Files/NSV Tundra TURNING SIGNAL RECALL.pdf
    Vehicle model:
    2019 Tundra CM TRD Sport
    With NSV installed:
    left turn signal light front and back working
    right turn signal light front and back working
    hazard light front and back working
    lowbeam working
    high beam working
    NSV Function:
    DRL working
    swipe working
    full light working
    adjustable headlight motor not working
    lights inside the truck is working
    I think the headlight adjusting motor is not getting any power
    the factory wire/connection for the adjusting motor has a purple wire, blue wire, and black/white wire
    anybody know how I can get that adjusting headlight motor working working?
    Thank you
    Mark
  2. Mar 25, 2022 at 11:25 PM
    Toyo18tundraSR5
    Toyo18tundraSR5 New Member
    18 fuel anza rims, summimoto 185/70/18, grill lights, nsv bar
    Mark, same issue here, ever find a fix?
  3. Mar 25, 2022 at 11:51 PM
    FlipMonkey21
    Mark
    SoCal Glendale
    Yup change the fuse under the driver side two fuses
