NSV Light Bar Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Vendeta2k, Jan 8, 2021.
  1. Jan 8, 2021 at 9:51 AM
    Vendeta2k
    Vendeta2k [OP] Distinguished Member Of The Cement Club
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Hello all! I did a quick search and couldn't find a definite answer. Is it possible (without being crazy difficult) to get the NSV light bar to work independent of the high beam / low beam settting? I would like to just be able to turn it on and off as applicable. Thinking about picking one up with the tax return this year.
    As always any help is greatly appreciated!
  2. Jan 9, 2021 at 10:50 AM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    It can be done, but requires modification of the harness. You lose the fog lights and sweep I believe, just becomes a simple on/off via a switch.
    Saltyhero13 likes this.
  3. Jan 9, 2021 at 12:19 PM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    That's the one feature I do not like about mine.
  4. Jan 9, 2021 at 12:44 PM
    NateG
    NateG New Member
    Nate
    2015 SR5 Double Cab
    So you don’t like the fact the the high beams are on at the same time as the light bar? You want to be able to toggle it via a separate switch and not the high beam switch?
