NSV light bar DRL brake light problem
Discussion in 'Lighting' started by lawrenceb, Oct 15, 2018.
  1. Oct 15, 2018 at 3:54 PM
    lawrenceb
    lawrenceb [OP] New Member
    2019 Tundra TRD Pro
    Installed the NSV light bar in my 2019 TRD pro.. followed the online video and downloaded the instructions. When I press the brake pedal the DRLs on the light bar light up.
    I used the T-Tap blue wire as instructed and connected to the purple wire on the headlight motor.
    Whats even weirder is I plugged the factory stalk harness back in and the light bar DRLs still light up when the brake pedal is pushed. Anyone have a clue what the problem is?
  2. Oct 15, 2018 at 4:31 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    @Headlight Revolution or @iHacker may be able to help here, but it sounds like you connected it to the wrong wires. HR has some YouTube videos that may be useful to make sure you're connected correctly.
