Not sure what these wires control. Help please
Discussion in '2nd Gen Tundras (2007-2013)' started by Tjboatboy, Mar 24, 2018.
  1. Mar 24, 2018 at 2:26 PM
    Tjboatboy
    Tjboatboy [OP] New Member
    maine
    2012 white tundra TRD
    2"level lift. TRD true dual exhaust. LED back up lights 6 LED'S per light. (2)
    Hi, I have a 2012 tundra club cab Trd. I have installed a bull bar and a 25"light bar. I was looking to mount a switch in the blank either to the right or left on the USB AUX port. The 2 blanks have wires in them. I don't know what the wires are for . Usually blanks do not have any wires. Any help will be appreciated. I have included pics of the wires and location, Thanks, Tj
    Y0TA PR0 and Mountun Goat like this.
  2. Mar 24, 2018 at 2:31 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Glass breakage sensor for alarm? Can't tell since I can't see the front of the "blank". What trim is your truck? Welcome from CO!
    Eclipsed & Floating likes this.
  3. Mar 24, 2018 at 2:50 PM
    Tjboatboy
    maine
    Sorry for not giving more info. The truck is soo dirty. Just had a storm and now the snow is melting
    boostedtrdpro and Mountun Goat like this.
  4. Mar 24, 2018 at 6:43 PM
    Tjboatboy
    maine
    The pic is of the outward side of the blank. Toward the driver
  5. Mar 24, 2018 at 7:07 PM
    Nick T
    Nick T New Member
    Nick
    Pre wired for heated seats? Factory location for heated seats control.
    boostedtrdpro likes this.
  6. Mar 24, 2018 at 7:07 PM
    boostedtrdpro
    Jeremy
    It's not the glass breakage sensor that's for sure. I'm at a loss not knowing much about the 2nd gens. Maybe @TundraTex may know?
  7. Mar 24, 2018 at 7:25 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome!
  8. Mar 24, 2018 at 7:28 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just shove it back in the hole and use the blank spot.
  9. Mar 24, 2018 at 8:42 PM
    Benstoy
    Benstoy New Member
    2008 Tundra Crew Max 4x4
    3/1 ready lift, added step bars, blue tooth, back up camera, assault roll up tonneau cover...has spray in liner, fender flares, leather
    I understand the far left and right to be heated seats, but not sure on middle.
  10. Mar 24, 2018 at 9:25 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Glass break sensor and heated seats.
    Tundyfundy likes this.
  11. Mar 24, 2018 at 9:29 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    This is Almaboy craftsmanship! Please don’t steal my technique
  12. Mar 25, 2018 at 2:06 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Based on the wire color and location, the left spot is for the left seat heater control and the spot to the right of USB is the Glass breakage Mic wires. The far right spot would be for the right seat heater controls. I agree with Joon and Alma, I would zip-tie and stow the connectors behind the panel.
    boostedtrdpro and NewImprovedRon like this.
  13. Apr 20, 2018 at 3:56 PM
    JGN
    JGN New Member
    JOHN
    2007 TUNDRA SR5 4X4 DOUBLE CAB LONGBED
    It is a pre wired thing that Toyota does so you add the accessorie that just add the switch. Just zip the back and use the blank.
  14. Aug 27, 2020 at 7:44 AM
    Horwood
    Horwood New Member
    Can I steal the power from one of them for some interior lighting I am trying to install? Seems better then running a new one from the box.
  15. Aug 27, 2020 at 1:44 PM
    Horwood
    Horwood New Member
    Solved, I just took it from one of the Cig lighters that has never worked anyway and put the 10 AMP fuse I needed inline. Never reconnected the cig lighter and ordered and "Eject" button plug for the dead outlet, truck has 3 others.
