Not sure if 4wd engaged
Discussion in '1st Gen Tundras (2000-2006)' started by lc69hunter, Aug 5, 2018.
  1. Aug 5, 2018 at 7:43 PM
    lc69hunter
    lc69hunter [OP] New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    Have had my Tundra for less than a month. Runs well, etc.
    However, today I pushed the 4wd button, and it started blinking, as well as the indicator on the dash. 4wd low didn't do anything.
    Heard the system engage when I pushed the 4wd button, but do not know if it actually did so.
  2. Aug 5, 2018 at 7:53 PM
    Casper421
    In the woods
    06 DC
    Did the light and indicator for 4HI become solid or just keep flashing?
  3. Aug 5, 2018 at 8:04 PM
    lc69hunter
    Don
    continued flashing
  4. Aug 5, 2018 at 8:05 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Flashing means not engaged or disengaged yet
    Solid means engaged
    Once 4wd is engaged to 4 hi you will have to come to a complete stop and put it into neutral then hit the 4 lo button.
    Happy Wheeling
  5. Aug 5, 2018 at 8:07 PM
    Casper421
    In the woods
    06 DC
    You heard it engage even though the lights were flashing?
  6. Aug 5, 2018 at 8:12 PM
    lc69hunter
    Don
    sounded like it.
  7. Aug 5, 2018 at 8:14 PM
    Casper421
    In the woods
    06 DC
    Try again, move forward a foot or two and see if the lights stop flashing. Once and if the lights become solid, put in neutral and try 4lo.
  8. Aug 5, 2018 at 8:22 PM
    Mr Swervlin
    O H I O
    This would happen to me every once and awhile. Try putting it in reverse. Roll a few feet then back to drive. If it's engaged you will know by turning your wheel all the way to one side. When you give it gas the front of the truck will hop around the turn. If it doesn't hop then it's not engaged
  9. Aug 5, 2018 at 8:43 PM
    lc69hunter
    Don
    Drove it up the street on pavement. It feels and acts like it is in 4wd. I know what that feels like, as I have 2 landcruisers, an FJ40 and an FJ55.
  10. Aug 5, 2018 at 8:47 PM
    Casper421
    In the woods
    06 DC
    Still blinking?
  11. Aug 5, 2018 at 8:58 PM
    lc69hunter
    Don
  12. Aug 5, 2018 at 10:09 PM
    Casper421
    In the woods
    06 DC
    Sounds like an issue with one of the actuators. Read this link, guy had the same issue and was able to eventually fix it:
  13. Aug 8, 2018 at 4:11 PM
    lc69hunter
    Don
    I will pursue it further this weekend, but finally got someone in the cab push the button, while I was trying to find where the sound was coming from under the vehicle. I think the actuator was trying to engage, but not doing so.
    I will jack it up and drop the skid cover this weekend, and then tap it with a hammer to see if it will engage
    Casper421 likes this.
  14. Aug 8, 2018 at 4:28 PM
    15whtrd
    15whtrd Mr. Blonde
    Probably time for a new actuator
  15. Aug 8, 2018 at 5:20 PM
    Casper421
    In the woods
    06 DC
    Check that the 4x4 relay isn’t toast before replacing the actuators.
    15whtrd likes this.
  16. Aug 11, 2018 at 5:31 PM
    lc69hunter
    Don
    Sitting in a parking lot today. Started it up, and just on a whim, pushed the 4wd button while in Park. It engaged. Put it in neutral, pushed the 4wd low, and it engaged.
    Haven't been able to duplicate it again.
    because_wumbo-truck likes this.
  17. Aug 12, 2018 at 9:25 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I'm not sure if it's a good thing when our vehicles start fixing themselves. Glad you haven't had it happen again. Happy wheeling/exploring.
  18. Aug 31, 2018 at 7:05 PM
    lc69hunter
    Don
    Update on the above. As I managed to get it into 4wd on rare occasions, and started driving in 4wd once I got it there, it goes into 4wd more and more often on the first try. I am suspecting that the previous owner probably never had it into 4wd once the whole 6 years he owned it.
  19. Sep 1, 2018 at 6:31 AM
    Professional Hand Model
    Hand Protectors
    You could be onto something Hunter. Keep working it. Maybe do some driving in reverse when you get into 4wd again.
  20. Sep 1, 2018 at 8:11 AM
    15whtrd
    15whtrd Mr. Blonde
    Yep I do the same. Haven’t done 4low. Maybe I should do that as well.
    NewImprovedRon likes this.
  21. Sep 1, 2018 at 8:23 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah that’s hard for part for me. Not much dirt roads around my house. I do 4high down a long straight stretch of road on my way to work. 4 low would have to be only for about a block long down my street or at our maintenance service yard entrance.
  22. Sep 1, 2018 at 8:41 AM
    lc69hunter
    Don
    Question: Do you turn off overdrive when in 4wd? I always do when pulling a load. And when I think of it, when I drop into 4wd.
  23. Sep 1, 2018 at 8:43 AM
    15whtrd
    15whtrd Mr. Blonde
    I haven’t towed anything in four-wheel-drive. But I always use S mode and shift up if I need it. D is rarely used in my truck at anytime LOL
  24. Sep 1, 2018 at 9:02 AM
    Hand Protectors
    Never have thought to turn off OD while in 4wd as the speed minimum requirements (per manual) in LO would never be breat enough to engage the OD. Doing mostly sand driving, the 02’ rarely has to be engaged in 4LO. She spends 99% of her time in HI when offroading.
    Towing: The 02’ is only switched out of OD on windy days (at high speed) where the wind resistance plays havoc at that shifting point. Otherwise, its always in OD. I’ve heard others here say to always keep OD off when towing, but I’ve never had problems unless the wind resistance factors in at speed.
