Not sure 5.29's were the right choice for me, thoughts?
Discussion in 'Performance and Tuning' started by 20quicksand, Sep 19, 2022.
  1. Sep 19, 2022 at 7:14 PM
    20quicksand
    20quicksand [OP] New Member
    2020 Quicksand Tundra
    New to the forums here and I'm looking for some advice / perspective. I have a 2020 Tundra that I've been building for the past year. The build currently includes Icon Stage 9 suspension, Nitto Ridge Grappler 35x12.5x17 tires on Method 704's, a Leitner bed rack, full overland skid plates, and sometimes a tent.
    When it comes to gears I spent countless hours researching whether to go with 4.88's or 5.29's and probably read every thread in this forum on the subject. The standard advice seemed to be 35 or smaller tires go 4.88, anything larger go 5.29. It seems though that there are a lot of people here that have gone with 5.29's on 35's and love it. I spoke with multiple shops that work on many Tundras, including SDHQ, and spoke with Nitro Gear and Revolution Gear. Long story short, advice was down the middle. Even taking into consideration the extra weight and potential for even more weight in the future if I add a bumper and sliders and driving condition of maybe 70% highway and 30% off-road / dirt-road, about half the people I talked to recommended 4.88's and the other half recommended 5.29's.
    Ultimately I went with 5.29's because of the additional weight I was adding. In terms of the driving experience they've been a massive change over stock in my opinion. With stock gears and tires, the truck wouldn't shift in to 6th gear until I hit about 75mph. Now the truck is in 6th gear at 55-60mph, depending on how hard I'm accelerating. RPM's are what you would expect from the typical calculations, at 70MPH the truck is running between 2100 and 2200rpm. The thing that's really driving me crazy, and making me question whether or not I should have gone with 4.88's in my case, is how quickly the truck moves through each gear and the drop in fuel efficiency. With stock gears and tires the truck was getting about 15.5 - 15.8 indicated mpg per tank and now it's getting about 12.8, and that's with mostly highway driving living in rural Texas.
    I understand Tundra's don't get the best mileage to start with but that 3mpg loss shaves nearly a 100 miles off my range on a single tank of gas. My intention with the build was to balance being fully capable off-road but also perform well on the highway getting places. I've read about folks getting near stock fuel efficiency with 35's after re-gearing and so I can't help but wonder if I over did it with the 5.29's. My questions for folks here are: Are you running 35's with 5.29's or 4.88's? How much additional weight are you carrying? What's your gas mileage? If you have experience with both, what would I notice different in terms of drivability if I re-re-geared?
    It makes me sick thinking about spending that money again but having a truck that doesn't meet my needs might be worse.
    TL;DR Not sure 5.29's were the right choice in my situation, thoughts?
  2. Sep 19, 2022 at 7:32 PM
    Vizsla
    Vizsla 2 = 2.5
    Did you adjust the PCM calibration for the gears and tire size?
  3. Sep 19, 2022 at 7:35 PM
    20quicksand
    Yeah, I forgot to mention I installed a Hypertech so the indicated speed is spot on.
    Tundra'25 and Backslider like this.
  4. Sep 19, 2022 at 7:35 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    35? 5.29 all day
  5. Sep 19, 2022 at 7:36 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Yeah, calibrate for new gears and tire size and you'll see a big improvement.
    I think the hypertech speedo calibrator allows changes to gears and tire size.
    HulkSmurf14 likes this.
  6. Sep 19, 2022 at 7:37 PM
    Backslider
    Tooele, UT
    You might also have the transmission control module reset so you can relearn shift points, etc.
    Full disclosure: I wouldn't go higher than 4.88 gears with 35s for the reasons you are experiencing. I know a lot of people will claim it's great, but it definitely makes the truck less enjoyable as a daily driver.
    Sierradevil likes this.
  7. Sep 19, 2022 at 7:38 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    @dirtydeeds
    He will set you at ease. You made the right choice.
    texasrho83 and JCBerb like this.
  8. Sep 19, 2022 at 7:40 PM
    MadMaxCanon
    Also take a long drive to where you know the mileage then compare to what truck thinks you traveled. Then get gas and see what the true number is for mileage.
  9. Sep 19, 2022 at 7:41 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    5.29 was the right choice.
    if your mpg ‘went down’ something is wrong because that is not what happens
  10. Sep 19, 2022 at 7:47 PM
    20quicksand
    They Hypertech does allow adjustments for both but I found that when I adjust for the measured tire size and the new gear ratio, the indicated speed is way off. Right now I just have it set to adjust for tire size and the speedometer is dead on.
    Any ideas what could be wrong?
    Backslider[QUOTED] likes this.
  11. Sep 19, 2022 at 7:51 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    So it sounds like you actually haven’t programmed the ECU that your gear ratio is 5.29. The Hypertech does not do it. You’ll need something like an HP Tuner.
  12. Sep 19, 2022 at 7:52 PM
    Vizsla
    Vizsla 2 = 2.5
    If I remember correctly, that only corrects the speedometer and odometer. Correcting the actual PCM does not correct the speedometer, but does correct shift points etc..
    Cruzer and Backslider like this.
  13. Sep 19, 2022 at 8:03 PM
    20quicksand
    Thanks for suggestion, I'll have to do some research and give that a try. In the mean time, I'm still curious if anyone has a similar set up, 35's and 5.29's, maybe with a corrected PCM, and can actually say they get 15mpg highway.
  14. Sep 19, 2022 at 8:07 PM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    I have 36s and didn't change shit lol idk about you guys switching gears for 35s :crazy:. Imo it's just the pedal response that sucks and makes it feel like it needs gears. Get a pedal commander and call it a day. Worked great for me, and I just ran moab this weekend lol
  15. Sep 19, 2022 at 8:14 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    35s and stock!!!
    excelw, Sierradevil and Wahayes like this.
  16. Sep 20, 2022 at 7:04 AM
    dirtydeeds
    Keith
    USA
    The Hypertech is usually wrong when you adjust everything right. You have to just eyeball changes to the unit until three speed matches your gps.
    The most common variable is a calculation error. After that, the possibilities are needless and I would just be guessing. But somethings off, 100% of the tine, your scenario should gain mpg, not lose it. (When comparing to stock gearing with large tires)
    snivilous likes this.
  17. Sep 20, 2022 at 7:09 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    My unpopular opinion.
    Turn nannies off, drive exclusively in S mode. I get 11.3 - 12.3mpg (GPS indicated). Highway speeds up to 80mph.
    <-------- Topper with 300lbs of gear/ tools in bed. Stock gears w/ 37's for nearly 40k miles.
    Single passenger, no tow, except for an occasional utility trailer most of the time.
    Transmission fluid looks normal after drain and fill.....YMMV
    I'd like gears. Hard for me to justify the cost vs benefit though.
    Sorry to hear OP. Time for a 46gl Transflo tank?
    edit to add: Daily driver/ work truck, country driving/ interstate, no stop and go commuting.
  18. Sep 20, 2022 at 7:20 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I didn't experience any change in mpgs when I went to 5.29s, I'm honestly amazed you ever got 15mpg to begin with. Something sounds wrong with that much drop.
    I guess I'm one of those people :rofl: I daily drive mine 25k a year and 5.29s makes it way more fun to drive. If strongly care about fuel efficiency, and you actually see a decrease with 5.29s then you have a point. I have only good things to say about 5.29s, out of curiosity what made it less enjoyable for you?
    Platinum714 and HulkSmurf14 like this.
  19. Sep 20, 2022 at 8:29 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Something doesn't sound right, my mpg went up after 5.29s, and that's hand calculated, not based off the display.
    I have skinny 35s that measure nearly true 35", I daily drive mine and on most days it weights around 6800-6900lbs, before supercharger I would regularly get 15-16mpg after regear, before that it was around 13-14mpg.
    Platinum714 likes this.
  20. Sep 20, 2022 at 8:30 AM
    Backslider
    Tooele, UT
    I didn't regear my Tundra to 5.29s, but drove in someone else's. High revs, limited max speed was my complaint. I felt like both my my Tundras (a 2016 and a 2020) felt and performed better as daily drivers than the one I drove with 5.29s.
    I've also read and heard from my local expert that deeper gears have a smaller pinion gear and are more likely to break. Coupling this with my experience driving one I didn't see any reason to go deeper than 4.88s.
  21. Sep 20, 2022 at 8:33 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Limited max speed? Please elaborate.
  22. Sep 20, 2022 at 8:36 AM
    Backslider
    Tooele, UT
    Truck seemed to top out at around 88 mph, if I recall. The owner said that he noticed this as well and that his max speed had decreased somewhat after regearing. Prior to the regear I think he was able to get above 100mph.
  23. Sep 20, 2022 at 8:37 AM
    Backslider
    Tooele, UT
    The truck I drove had 5.29s and true 35's with something like a 3/2 coilover/shackle lift.
  24. Sep 20, 2022 at 8:38 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I see. It sounds like that person also did not update the ECU/PCM that the gear ratio was changed to 5.29s. I experienced something similar until I finally made the update. 100mph+ no problem.
    snivilous and Backslider[QUOTED] like this.
  25. Sep 20, 2022 at 8:39 AM
    snivilous
    SW UT
    A stock truck seems to be governed by rpm more so than the speedometer/wheel speed sensors. If your ecu is flashed then it's not an issue.
    texasrho83 and Backslider like this.
  26. Sep 20, 2022 at 8:42 AM
    king.cong.1119
    king.cong.1119 New Member
    35s with stock gearing and fully loaded the truck, getting about 13-15mpg. But, I rarely exceed 65mph, when I really need that extra torque, I turn on the tow/haul mode momentarily.
  27. Sep 20, 2022 at 8:43 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    An aftermarket tune is gonna make everything better for ya.
  28. Sep 20, 2022 at 8:44 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I knew something was wrong when I tried to pass a vehicle on a 2 lane road and the governor kicked in while I was right next to the car while there was another vehicle coming at me. Scared the shit out of me. Had to slam the brakes to get back behind the car.
  29. Sep 20, 2022 at 8:51 AM
    Vizsla
    Vizsla 2 = 2.5
    It is limited by the speed rating on the original tires, there are different stock limits depending on what tires the truck was equipped with though. The 5.29s throw it off and results in the lower top speed. I lost 1-2mpg with 5.29s(this might be due to the 18+ trucks calculating things slightly different), supercharger makes your results not applicable for n/a.
  30. Sep 20, 2022 at 9:12 AM
    snivilous
    SW UT
    My comment is in regards to what is throwing it off. I always assumed the "governor" was based on the speedometer/wheel speed sensors, but that's obviously not the case. The truck seems to reference rpm and governors itself effectively at ~2800rpm in 6th gear, and NOT based off ~108mph. The rpm governor is based off the stock tires and gearing sure, but the fact it's based on rpm in 6th (presumably) is why the top speed is reduced when regeared. I assume 4.88s have the same issue and top out in the high 90s. Easy to bypass that with a tune, since it's an electronic limiter and not a physical hardware limitation.
