Not so New but I am back
Discussion in 'New Member Introductions' started by pcajun, Feb 20, 2022.
  1. Feb 20, 2022 at 3:41 PM
    pcajun
    pcajun [OP] New Member
    2009 Tundra 5.7L SR5
    Greetings,
    I have a 2009 Tundra SR5 with 5.7L engine. Truck now has 167,000 miles on it and I am the original owner. Have had no problems from this truck up until our first cold spell and have been pulled down into the Secondary Air Pump and Switching Valves rabbit hole. Was replacing the switching valves this weekend and discovered a cracked fuel injector. I decided to leak check everything and just leave the bad fuel injector unplugged.
    The truck has now resorted to the Limp Mode (again) but I am figuring it is due to the unplugged fuel injector. New one is on the way and should arrive Tuesday. Tallahassee Fl. apparently does not have any fuel injectors available for such popular engines.
    Anyway in order to allow me to sleep for the next two nights....can any confirm that unplugging a Fuel Injector will force the vehicle to default into the Limp Mode? If not I will run this question through my mind at night for the next few days.
  2. Feb 20, 2022 at 3:51 PM
    Welcome from NY.
  3. Feb 20, 2022 at 4:21 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Can't help with your question, but welcome from LA (Lower Alabama)!
  4. Feb 20, 2022 at 5:41 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  5. Feb 20, 2022 at 5:52 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
