Not Hiding Anything...
Discussion in 'New Member Introductions' started by whiggy, Aug 6, 2025.
  1. Aug 6, 2025 at 7:10 PM
    whiggy
    whiggy [OP] New Member
    Over the past 24 years and 226K miles this 2001 4.7L V8 SR5 slowly took its clear coat off, rolled up its fender flares, leaned over casually and said to me in its best FL redneck voice - "I'm jus' gitn' starded an' I'm ready... are you??!". Basically, it made me an offer I could not refuse so... it's mine!!!
    I am still debating on whether to try to fix the paint and make it look like a botched plastic surgery or just let it age gracefully the way it is and wear its wrinkles, scars, and other old age signs proudly... I have a feeling if I fix the paint it's going to be "just some old truck" but if I leave it as is it will retain its true identity :D (plus I won't care if it gets scratched or something like that, lol). The camper/shell/topper... whatever you call this... has to go, tho. Anyone want it?
    Suggestions are welcome, of course.
  2. Aug 6, 2025 at 7:21 PM
    Mr Badwrench
    Mr Badwrench New Member
    If it's running great, or great enough, leave it alone...Is my way of thinking. There are things that will eventually catch up though.
    You've probably read it all though.
    2mchfun, mrlittlejohn and whiggy[OP] like this.
  3. Aug 6, 2025 at 9:11 PM
    aidan2ndson
    aidan2ndson New Member
    2006 Gray Toyota Tundra
    I'm glad you asked, because I took one look at that camper shell and thought, "Ah wont thayet."
    whiggy[OP] likes this.
  4. Aug 7, 2025 at 3:39 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Timing belt? LBJs - age and OEM? Radiator - Denso and not brown/old?
    whiggy[OP] and 2mchfun like this.
  5. Aug 7, 2025 at 3:52 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    You may have a FL twin with @Bmktw2
    Only his had considerably more rust.
    On the paint, it’s just sort of a thing that happens, FL sun doesn’t help. You really need to keep a good UV-protecting wax on it and park in the shade sometimes, else that’s the end result. A selective repaint (hood, roof between rail provisions) may help? Truck does look good!
    Bmktw2, whiggy[OP] and 2mchfun like this.
  6. Aug 7, 2025 at 4:02 AM
    2mchfun
    Welcome from OKC! Congrats on your find! I vwould keep the shell and tow a small trailer or make a big custom hitch basket for "truck bed" duties. That way you can adopt a cool pup or two too and they can have a seperate spot to ride along in.:thumbsup:
  7. Aug 7, 2025 at 5:19 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Aug 7, 2025 at 5:37 AM
    Welcome from NY.
  9. Aug 7, 2025 at 3:40 PM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    I'd probably have the hood, roof and doors painted if for nothing else to keep it from rusting. Looks like the roof is rusting. Was the truck standing in Florida flood waters or is that from something else?
    Screenshot 2025-08-07 at 6.33.10 PM.png Screenshot 2025-08-07 at 6.34.41 PM.png
  10. Aug 9, 2025 at 8:50 AM
    whiggy
    Timing belt done ~60K miles ago. Radiator has been replaced with Denso. LBJs look acceptable for now but I will replace them when I get a chance. I watched a few videos and, if they are not rusted, seems like it could be a DIY job... idk, I'll cross that bridge when I get there.
  11. Aug 9, 2025 at 8:55 AM
    whiggy
    Yes, the roof is rusted and I believe it's just because the clear has been gone for so long that the FL sun ate thru the paint. It has not been in a flood. I have decided to prep and clear coat the hood and doors (blend in) and will paint and clear coat the roof after I get rid of the camper so I can access it easier.
  12. Aug 13, 2025 at 9:10 PM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD DC 4.7 V8 AT 2WD
    Welcome from NC
