Not down shifting appropriately to me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bmitchell2023, Jan 23, 2023.
  1. Jan 23, 2023 at 8:25 PM
    Bmitchell2023
    Bmitchell2023 [OP] New Member
    2021 Tundra TRD sport
    Question about transmission. My 21 seems to not be down shifting appropriately to me. Especially if you doing 45-50 and slow down to make a turn and accelerate pack to 30 mph. Is this common?
  2. Jan 23, 2023 at 8:42 PM
    AZBoatHauler
    So.Arizona
  3. Jan 23, 2023 at 8:45 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Can you describe it a little more for us? Mine tends to want to hold onto gears around that speed and takes more driving with the gas pedal to hold speed, rather than ride the brakes and coasting like my Highlander used to. I presume this is a brake-saving feature in particular in a hauling situation, rather like it myself.
  4. Jan 23, 2023 at 8:49 PM
    2mchfun
    How long have you had the truck? How long have you had the problem? What are you used to driving?
  5. Jan 24, 2023 at 4:51 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Seems very subjective. Is it just holding a gear? Has it always done this since you've owned it?
    2mchfun likes this.
  6. Jan 24, 2023 at 9:33 AM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Mine seems to do this as well (down shift hard). It's strange, but I find it only happens when I ease back on the throttle to start accelerating back up to 50ish mph. When I'm slightly more aggressive the truck seems less confused and downshifts appropriately.
  7. Jan 24, 2023 at 10:24 AM
    Bmitchell2023
    Bought the truck used with 20k miles. Sold a GM truck for this one. Only happens if I slow down quickly and then accelerate after a turn. Should be down shifting and it’s not. No load on bumper or bed. It now has 25k and has done it since I bought it.
  8. Jan 24, 2023 at 10:40 AM
    art64
    art64 New Member
    There maybe an aftermarket tune installed on that truck. Have dealer check.
  9. Jan 24, 2023 at 4:27 PM
    WaterTrash
    WaterTrash New Member
    Fluid level?
  10. Jan 31, 2023 at 4:04 PM
    Bassballs75
    Bassballs75 New Member
    I know what you're talking about. It drives me crazy, my 08 and my 19 did something similar on the same turn on the same corner. I would slow down and make the turn the truck would down shift and I would accelerate easy on to the side road and it would almost sound like it was slipping and bang pretty hard back into third. So I started accelerating harder to see the difference in the shift and it was a much cleaner shift. But it's a quite street with kids around so now I put it into manual before the turn and shift it when I need.
    Bmitchell2023[OP] and CMikeB like this.
  11. Jan 31, 2023 at 4:08 PM
    Wallygator
  12. Jan 31, 2023 at 4:53 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Tundras have really wacky shift points from the factory imo. When I got tuned, one of the first things I appreciated the minute I hit the gas was the much improved shifting.
    Bmitchell2023[OP] likes this.
  13. Feb 1, 2023 at 2:26 AM
    CMikeB
    CMikeB New Member
    I've forgotten how long it's been since I drove my truck in "D." No "shifting issues" for at least 11 years!:D
    Wallygator likes this.
  14. Jan 29, 2024 at 5:39 PM
    Dottat
    Dottat New Member
    I've isolated this down in my truck to the downshift from 5th to 4th. I first noticed that this was happening going down hills with my feet off the brakes and gas. I would tap the brake and instant the truck would downshift and make a pop sound. I now can recreate it on a flat road with no braking using the s mode shifting between 5 to 4th. But not every time. I think it depends on whether the speed of the truck has the torque converter locked.
    I have a feeling we are all experiencing the same. Curious if anyone has done any real troubleshooting of this.
  15. Jan 29, 2024 at 5:42 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Mine will downshift like how you explain but no pop sound. My 14 tacoma v6 I used to have prior also did it.
  16. Jan 29, 2024 at 5:44 PM
    Dottat
    Dottat New Member
    I'm not sure if Pop is the best word. It's smooth but definitely an audible sound that's much louder now that the truck is around 105k miles. Sort of feels like something a software tsb could address.
  17. Jan 29, 2024 at 5:59 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Curious for others to chime in. My truck just has a smooth downshift. No sound, no jerk, nothing. Just downshift and holds the rpm’s up to slow the truck down. I personally like it so I don’t have to ride the brakes.
  18. Jan 29, 2024 at 6:00 PM
    Dottat
    Dottat New Member
    How many miles on your 2020? Mine is a 2017 with 105k at this point. It wasn't like this when it was younger.
  19. Jan 29, 2024 at 6:21 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    71k. Mines worked the way I described since I drive it home with 6 miles on it.
  20. Jan 29, 2024 at 6:24 PM
    Dottat
    Dottat New Member
    I would estimate I started to pickup on this sound around 90k.
  21. Jan 29, 2024 at 6:25 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I’ll be at that around this time next year so we’ll see what happens!
  22. Jan 29, 2024 at 6:26 PM
    Dottat
    Dottat New Member
    One thing I would say is that I wish I had done my gear oils and atf sooner. Not sure if that's a factor yet or not.
  23. Jan 30, 2024 at 2:00 AM
    Oolypoolay
    Oolypoolay Meh
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    If you have techstream you can try to reset the memory on the trans.
