Not an intake whistle but a whistle
Discussion in '2.5 Gen Tundras (2014-2021)' started by daesong, May 29, 2019.
  1. May 29, 2019 at 7:50 PM
    daesong
    daesong [OP] New Member
    im trying to find a whistle sound that is consist with wheel speed not RPM. i have this constant whistle that i can hear very well around 50-60km/h. i do believe there is faint of whistle at a very low speed and higher speed (around 80km/h) also. every time i try to search for the whistle on tundra but all i find is intake whistle problems. the whistle sound that i get is so similar to the intake gasket whistle but its bit lower pitch whistle. i hear it normal driving 50-60km/h but when driving by wall or parked cars i can hear it very well. its coming from front or middle of the truck passenger side. its constant and consist with wheel speed.
    Pinski likes this.
  2. May 29, 2019 at 7:57 PM
    Welcome from NY.
    Do you have side window visors? If so there's your whistle.
  3. May 29, 2019 at 8:48 PM
    daesong
    just came back from driving without the visors and the sound is still there. i think its coming for front passenger wheel or bottom of the truck. could be u joint, drive shaft, differentials. i hope its none of these. i just hope its break dust guard on rotors but very hard to tell. it's the loudest at 55km/h and the pitch gets higher as the truck speeds up and the sound disappears below 40km/h. the high pitch is not as high as intake whistle
    thank you jim for ur advice tho
  4. May 29, 2019 at 9:01 PM
    :thumbsup:
  5. May 30, 2019 at 4:31 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Welcome.
    You don't say how old the truck is, how many miles, or when the noise started.
    Drive line components don't typically make a "whistling" noise, and if it were the brake back plate, all Tundras would have a similar whistle.
    From a wheel area, it could be tire noise. Did you get new tires? Try having the tires rotated and see if the noise moves with the tire.
  6. May 30, 2019 at 8:44 AM
    daesong
    sorry there about the lack of info. i purchased a used 2015 sr5 DC in november 2018. it has 110000km on it. did a 6500km cross country trip and half way through i begain to hear the noise. the noise started very faintly. only heard the noise because driving near a building but now i hear it all the time. ill try rotating the tire. the truck came with new ko2s and i havent rotated the tire since i bought the truck. maybe ill try rotating the tire and see if its the tires.
    Black Wolf and Pinski like this.
  7. May 30, 2019 at 8:51 AM
    daesong
    and the truck is bone stock trd off-road. the truck does pull to the right a litle and has a tiny steering shake when driving over 100km. i think i need a alignment but didnt got it done yet due to my work schedule.
    just wondering if the intake whistle is constant for the people experiencing it? or just on certain RPM?
  8. May 30, 2019 at 9:10 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I seem remember there being a similar issue with 2016+ Tacomas. On them, there was a hole in the lower control arm that would whistle. If you plug it with some kind of plastic/rubber cap the noise would go away.
  9. May 30, 2019 at 9:21 AM
    daesong
    do you know if the tacos have the same control arm design as the 2014+ tundras?
  10. May 30, 2019 at 9:46 AM
    Squatting Pigeon
    Holden
    North Texas
    I would imagine they are fairly similar but I couldn’t say for sure. Maybe take a look under there and if you see any holes in the arm tape over them and go for a ride
  11. May 30, 2019 at 4:02 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    Mine started doing this on a long drive a couple of weeks ago, and because I’m pretty OCD, I pulled over and started going through EVERYTHING. I found that my radio antenna was lose. I tightened it down by hand, and the sound stopped immediately. It had set up a harmonic that sounded like a whistle. It’s simple and easy to check.
    Black Wolf likes this.
  12. May 30, 2019 at 4:14 PM
    B0G4RT
    B0G4RT New Member
    Bo
    2018 SR5 TSS
    Coming soon
    All I can say is wheel bearings. Seriously check them. The “whistling” sound may be something else but I have had wheel bearings fail and they start off light and develop into a louder sound over time.
  13. May 30, 2019 at 4:16 PM
    B0G4RT
    B0G4RT New Member
    Bo
    2018 SR5 TSS
    Coming soon
    Also check your inner wheel well there are tons of plastic clips that can come loose and cause the plastic guards to catch air and make noises.
  14. May 30, 2019 at 5:35 PM
    daesong
    ill check all of the things you suggested get back to you guys.
    thank you
    B0G4RT[QUOTED] likes this.
  15. May 30, 2019 at 5:36 PM
    daesong
    ill check the antenna and get back to you guys
    thank you
  16. Jun 22, 2019 at 12:01 PM
    daesong
    i just cam back from a drive after plugging couple of holes and the noise is gone. you sir the real MVP!!. thank you
