"NOT" a will it fit thread, but a will it "WORK" thread
Discussion in 'Suspension' started by SMK Shoe, Mar 12, 2018.
  1. Mar 12, 2018 at 3:14 PM
    SMK Shoe
    SMK Shoe [OP] Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Been doing some research on my 2017 DC. Not wanting to do a full lift kit ( very little real 4 wheeling), but looking to lift a little and run meatier tires. These are my thoughts
    1. 6112 shocks up front ( looking for 1-1 1/2" )
    2. 5100's on the rear ( maybe all four corners looking at a few other threads)
    3. Fuel 18" rims ( Vector Antharcite ) Not sure of offset. I want close to stock offset, but do want them to stick out a little bit. more in line with the fenders.
    4.Running 275/65/18 stock michelins. Will bump up a little bit, more in the width than in the height dept. I like a wide tire in the fender wells. not a skinny/tall tire. Mostly a AT tire
    Anyone have any suggestions on this setup.
    If all goes right, will be piecing everything together, so when tires need to be replaced, the entire job can be done.
    Rims
  2. Mar 12, 2018 at 3:59 PM
    TheBeast The Beach
    damn those Fuels look a lot like the Methods NV...
    Backslider, Baja Mike and 831Tun like this.
  3. Mar 16, 2018 at 5:19 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    Well, pulled the trigger on the rim's. went with a +20 offset. Now to figure out the shocks. Didn't get much response, so will just wing it.:help:
    rons23 likes this.
  4. Mar 16, 2018 at 5:22 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    + 20 will push your tire out less than inch if it's the same width rim.:thumbsup:
  5. Mar 16, 2018 at 7:17 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    If you want to fill the wheel well get some 305/65 tires and get run 6112’s on 2.5” of lift with a small shackle in the back. That should give you a good ride and the look you want. I would skip the 5100’s as the 6112’s are a better shock. Never such thing as having too much shocks. Nice wheels btw.
    Theonlyway likes this.
  6. Mar 16, 2018 at 7:54 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    You can stuff 37x13.5 tires under there with that offset and lift if you want. Just gotta trim a little metal. Body mount chop is pretty standard. Then flatten the pinch weld. Trim the backside of the front bumper a tad.
    Here’s my wife’s tuck setup that way.
    And now with 0 offset
    OcotilloSR5, equin, aperezsh and 2 others like this.
  7. Mar 16, 2018 at 7:58 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Whoa 37s on a 2” lift!? That’s nutty. Badass and good to know
    KevinK[QUOTED] likes this.
  8. Mar 16, 2018 at 8:06 PM
    KevinK
    Tundras to Sedona
    Yuuuuup. :hattip:
  9. Mar 16, 2018 at 9:00 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    This is happening for sure to my truck :headbang:
    OcotilloSR5 and KevinK[QUOTED] like this.
  10. Mar 16, 2018 at 9:07 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Nice wheels
  11. Mar 16, 2018 at 9:13 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I’m confused on the definitions of work and fit apparently but either way just get what you want and make it fit just be a big boy and don’t be afraid to cut stuff if needed
  12. Mar 16, 2018 at 11:16 PM
    Eclipsed & Floating
    Voluptuous Whitey
    ^^ THIS!
    The first cut is the most difficult, but once that one happens then here comes Swiss cheese
  13. Mar 18, 2018 at 12:52 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    FUCK IT!!! CUT IT UP!!!!
    aperezsh and Mountun Goat like this.
  14. Mar 18, 2018 at 7:48 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I have zero issues cutting into mine haha. It’s old and I give zero f’s!
    KevinK, mudslinger79 and TheBeast like this.
