Northern New jersey
Discussion in 'New Member Introductions' started by CptnPhtm06, Apr 23, 2015.
  1. Apr 23, 2015 at 12:54 PM
    CptnPhtm06
    CptnPhtm06 [OP] New Member
    Jay
    06 Phantom Grey Tundra DC SR5 TRD
    2" lift with custom welded dual exhaust behind rear tires.
    Hey guys and gals if applicable, lol. Im new to the forum world and i actually cane on to find out if putting 1" wheel spacers will affect my wheel bearings ? How severly too for that matter if so. Thanks y'all!!!
    T-Rex266 likes this.
  2. Apr 23, 2015 at 1:34 PM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    Welcome!! There are a ton of guys running the 1.25s with little issues... Just make sure they are wheel and hub centric.
  3. Apr 23, 2015 at 5:08 PM
    CptnPhtm06
    Jay
    WhAt do you mean by that? Wheel and hub? centric
  4. Apr 23, 2015 at 5:24 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  5. Apr 23, 2015 at 7:34 PM
    Welcome! See the above posts.
  6. May 14, 2015 at 6:15 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Sorry I didn't see this sooner. I run a 1.25" wheel spacer. The reason for the extra .25" is to ensure its wider than the length of the lugs.
    Make sure you get a reputable brand (no eBay) and that it is 1" or wider with the separate set of lugs. Do not use the simple spacers that feed through the lugs that are really just glorified washers. These reduce the amount of effective thread on the lug nuts and could cause the wheel to fall off.
    To answer your question, anything that brings the tire outside of stock configuration could cause premature wear. This not only applies to wheel spacers but also aftermarket wheels that have more negative offset.
  7. May 14, 2015 at 6:22 AM
    What brand are your spacers and where did you get them if I may politely ask.
  8. Jun 12, 2015 at 10:08 AM
    CptnPhtm06
    Jay
    Havent purchased any yet. But now thinking of getting rims instead. I need a 4" back space though in a 16" diameter to keep my very expensive tires which are brand new. Who ever did the lift before me kept stock 06 DC tundra rims and upped the tires to 285/70/16 so i get a lil rub on control arms and frame on sharp turns. Any advice in where to find a 16" rim w/ 4" BS woud be greatly appreciated.
  9. Jun 13, 2015 at 7:15 AM
    csuviper
    Broomfield, CO
    Wheel spacers are spidertrax. They are fabricated in Colorado. Purchased through Toytec.
  10. Jun 13, 2015 at 11:44 AM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    Method Race Wheels has a few 16x8's... 6x5.5... 4.5" backspace... Zero Offset?
