Normal RPMs without towing?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Aggiekey, Mar 10, 2021.
  1. Mar 10, 2021 at 7:49 PM
    Aggiekey
    Aggiekey [OP] New Member
    Dustin
    2021 5.7 crewmax 4wd
    Leveling kit, 33 tires
    I have a new 2021 5.7 crewmax 4wd. I put a leveling kit, 20 inch wheels, and 33s. I feel like the truck is really struggling going up even moderate hills on the highway. To maintain 75mph, it has to pull 3400 rpms. Is that normal? Or do you think there is a problem? This is without towing anything. And I am in CO, so would the altitude make a difference?
  2. Mar 10, 2021 at 8:00 PM
    AZBoatHauler
    So.Arizona
    That sounds like 4th gear. Given the altitude and your described terrain, sounds normal. When it flattens out it should shift to overdrive and drop you somewhere around 2k RPMs but you’re making way more power at 3400.
    14burrito and jeremyd like this.
  3. Mar 10, 2021 at 8:01 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Yes altitude makes a considerable difference, denver you're losing around 15% power and up to like 30% or more loss at the peaks. That plus larger tires and increased cross sectional area don't help a truck that has a finicky cruise control/throttle programming to start with. Mine used to downshift all the time even if just a slight hill.
  4. Mar 10, 2021 at 8:03 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Yea I say normal, It's probably in 4th or 5th trying to maintain 75..
  5. Mar 10, 2021 at 8:08 PM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I'm in a relatively flat area, some hills but no mountains. 1500-1800 rpm normally, or 2000 if going a little faster.
    Your mods probably had little to do with it, I have 33" tires on 20" rims as well.
  6. Mar 10, 2021 at 8:08 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Welcome, truthfully I doubt there is anything wrong with the truck. The addition of a leveling kit will create more drag than a stock truck. Secondly it sounds like you added aftermarket rims and larger tires presumably all-terrains. Weight and height are always going to effect torque.
    The Tundra is almost a 6k pound truck...75 mph in mountains at higher elevations is going to cause high rpms. Honestly drive a little slower...
  7. Mar 10, 2021 at 8:14 PM
    Aggiekey
    Dustin
    Thanks. Yeah you’re probably right. I need to slow down, but hard when everyone is flying by. This is my first truck where I have gone away from stock wheels/tires and suspension, so it was a bit worrisome.
    Oey12[QUOTED] likes this.
  8. Mar 10, 2021 at 8:42 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Around 2.1k RPM on flat ground at 75mph (actual, not dash). I usually cruise at 70mph with 1.8-1.9k RPM on flat ground also. Not at high attitude like you though as I'm in San Diego.
    Truck is on 40" tires with 5.29 gearing and a supercharger.
  9. Mar 10, 2021 at 8:42 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Yeah I definitely get it, I don’t like seeing everyone flying by me. But in the end to get respectable mpg’s and not beat up on the truck is worth it IMHO. And at least you got one of the best damn 1/2 tons on the market :yay:
  10. Mar 11, 2021 at 2:00 AM
    Welcome to the site.
    Since you are just 29 min north of me, we travel a lot of the same terrain. You are at least 5800' and in some places in your city are 6000'. You lose ~3% hp per 1000' of elevation on NA engines. So you have lost 17-18% hp (68.5) just in efficiency losses which takes the power down to around 321.5 hp at the crank. Installing heavier wheels (20 vs 18) and bigger diameter tires with a leveling kit has some effects.
    Tips on the mountain passes. Use Tow Haul mode.
    This is why forced induction works really well in Colorado. :thumbsup:
  11. Mar 11, 2021 at 5:01 AM
    Aggiekey
    Dustin
    Thanks. I do want to go supercharger eventually. When I have built up some wiggle room with the wife.
    Also, love the work that the O’Keefe Music Foundation does. Especially with the Tool music.
  12. Apr 7, 2021 at 5:50 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I used to live in CSpgs. 3% per 1K elevation is the ROT on hp loss for NAS engines. I recently added 20” Fuel wheels and BFG KO2s and I am supercharged and hated how the truck felt. Back to stock wheels I went.
    In your situation you have probably a 25% overall power loss due to elevation with taller and heavier tire.
    For example: The KO2s are 57lbs ea and the stock Michelins are 44lbs...that’s 13lb increase per tire. The stock TRD 18” wheel is 31lbs...my Fuel Torques are 36lbs and they are about the lightest I could find in 20” wheels. So in my case I added about 20lbs per wheel/tire, increased the rolling resistance due to stiffer side wall and aggressive AT tread AND increased the overall tire height by 1 inch. It all doesn’t sound like much and it wouldn’t be if we were talking about a 3/4 ton diesel...but a NAS gas engine will be affected much more. Even with the S/C I could feel the engine laboring more, it ate way more fuel than it already does and the braking efficiency went down as well. Overall the wheels and tires look cool on a Tundra but in my opinion, the execution is shit.
    It’s unfortunate, bit it is what it is, and it comes down to what you can live with or without.
    Oey12 likes this.
  13. Apr 7, 2021 at 6:06 PM
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    Nail on the head, want stock performance...leave the truck alone. Add bigger tires, wheels, lifts. Performance and mg will suffer. You can’t have your cake and eat it too!
