Noooo Tundra Down
Discussion in '1st Gen Tundras (2000-2006)' started by Wes_heppy, May 24, 2021.
  1. May 24, 2021 at 9:59 AM
    Wes_heppy
    Wes_heppy [OP] Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    My inner fenders were all cracked and missing most of the clips and flopping around being very annoying. I have read about a few people just going without. I decided to take them out. This leaves the intake exposed right above the tire. Well i was out and about like an idiot driving through some puddles slinging water and mud everywhere not even thinking about it and it died. I gave it a few minutes and tried to start it. No luck. Pulled the plugs and tried to bump it to spew the water out. No luck wouldn’t even try to turn over. Water got all the way into the cylinders. The engine is hydro locked. Rods are probably bent and valves probably messed up. Anyway i need a new motor. Recommendations?? Also i will be doing the pull myself. My problem is that if i will be going to all the work to pull the motor and spend thousands i would really like to have a little more than 250hp when I’m done lol. I cannot seem to find built crate engines for sale stroker kits or anything like that. I cant seem to find ported heads or cams or any real performance parts either. Is an exhaust all there is to do on a 4.7 or what. Also what is a good rebuild kit for these if i cant find a junk yard motor? Thanks a lot any help is appreciated.
  2. May 24, 2021 at 10:12 AM
    18" TRD Off Road Wheels
    @empty_lord is who I'd ask in the 1st gen world. He's done some vehicle saving. For performance, maybe @dirtydeeds knows something for the 4.7?
  3. May 24, 2021 at 11:08 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Swap in a 2ur and gimme pics. If id done that, id swap in a stock runner, and try to build the original. Or ls swap. Or 1kz swap. Or ?12ht? Or 4-53 detroit. But i would really want a 1vd. Where you at? Ive got an extra ‘04 sequoia longblock. Well, or an ‘02 tundra longblock depending on results of a compression test.
    im sure reman longblocks arent too pricey. plus, im kinda looking for trades.
  4. May 24, 2021 at 11:13 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Stick a used 2UZ-FE in it, replace your fender liners, don't drive through giant mud holes. That should be your plan.
  5. May 24, 2021 at 11:25 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Find a lotus 2zz with the blower.
  6. May 24, 2021 at 1:42 PM
    Just LS swap it and be done. Pick your horsepower.
    SouthPaw and KarmaKannon like this.
  7. May 24, 2021 at 1:55 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Those wuhan war whistled 4.8s are mighty impressive.
    KarmaKannon likes this.
  8. May 24, 2021 at 3:53 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Used low mileage 4.7, do headers and enjoy more power and a long living engine
    do the t-belt, rear main and front cam and crank seals while it’s apart. Valve cover gaskets too. Should make for a long lasting leak free motor
    KarmaKannon, N84434, Darkness and 3 others like this.
  9. May 24, 2021 at 4:15 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Dude, you were begging for it....
  10. May 24, 2021 at 6:04 PM
    empty_lord
    05 rollover special
    The other option is to get a 3uz out of an LS430... more power. Lighter weight engine. Fabricate some motor mounts and itll bolt up to the trans..
  11. May 24, 2021 at 6:06 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    I like that plan... Hmmm I already had headers.
  12. May 24, 2021 at 6:07 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Yeah definitely not my finest moment.
  13. May 24, 2021 at 6:09 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    I would but I would need a 5.3 or a 6.0, a trans, transfer, standalone ecu, drive lines, everything would need to be made custom and I don’t have 15k to spend and a few months or i would.
  14. May 24, 2021 at 6:10 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Likely what will happen unfortunately and it was a surprisingly small hole not even 1/2 way up the tires. Buddies stock 4Runner went right through.
    Cg13055 likes this.
  15. May 24, 2021 at 6:18 PM
    empty_lord
    05 rollover special
    The UZ series engines are surprisingly very modular. The 4.7 heads should bolt up to a 4.3. How will it affect power? Not sure. But mixing and matching would make something interesting.
    but if you can find a ls430 donor for its ECU and engine plus the harness, you’ll be doing ok. I think they came with the a750 at some point. So a trans from an newer tundra or sequoia with the VVTI 4.7 and a FJ manual transfer case would make it an interesting build.
    But in all reality I would highly recommend a low mileage 4.7 and reseal everything while it’s out of the truck. Coupled with headers and a VVTI intake manifold you should get a bit of a bump in power.
    or find a donor truck with the vvti 4.7 and enjoy that big bump in power
  16. May 24, 2021 at 6:20 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Ahh, must go slow, thru unknown Waters, young grass-smoker! :D
    KarmaKannon and Darkness like this.
  17. May 24, 2021 at 6:25 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    What years of 3uz would bolt up? Also should i do a stand alone instead of a whole wiring harness?
  18. May 24, 2021 at 6:26 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    The best option for me might be to throw a vvti in it, swap my long tubes over, and cams. Less guess work and mo powa.
    Cg13055 and FrenchToasty like this.
  19. May 24, 2021 at 6:33 PM
    empty_lord
    05 rollover special
    So. VVTI would take a bit more work to make the headers work. UNLESS the engine was from a VVTI 4runner. I don’t think those got the air injection bullshit
  20. May 24, 2021 at 6:36 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Ah okay. Like what kind of more work?
  21. May 24, 2021 at 6:38 PM
    empty_lord
    05 rollover special
    The air injection ports would need to be blocked off. The headers sold to delete the system have little nubs to seal the holes
  22. May 24, 2021 at 6:39 PM
    empty_lord
    05 rollover special
    Ok correction. I had a moment, BUT the vvti 4runners also have air injection.
    So yea... it’s a little extra work I’d say
    Cg13055 and Wes_heppy[OP] like this.
  23. May 24, 2021 at 6:41 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    How about for what years of 3uz would work with the tranny?
  24. May 24, 2021 at 6:42 PM
    empty_lord
    05 rollover special
    I’d have to do some digging. BUT I do believe some came with the a750 (albeit with a 2wd version). But the ecu can likely control a 4x4 a750f and you’d just need to wire up the 4x4 or go to a FJ manual case.
  25. May 24, 2021 at 6:45 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Okay so about any 3uz with a wiring harness would work if i wire up the 4x4.
  26. May 24, 2021 at 6:45 PM
    empty_lord
    05 rollover special
    Hmm. They came with the a761 or the 650. So this would involve a lot of extra digging to see if the a760 out of a newer 4.6 tundra would be useable.
    basically we keep coming back to just swap a stock 4.7 in.
    Or run a 3uz off the vvti 4.7 ecu and a a750f
    but then you need to disable the SAIS or deal with a check engine and limp mode for ever
  27. May 24, 2021 at 6:51 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Yep kinda lookin that way. An 05 is vvti right? There is an 05 4.7 on Craigslist near me right now. Says it runs good no leaks.
  28. May 24, 2021 at 10:39 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    If we're lucky this will go viral and FGT prices will come back to earth. In the meantime, sorry for your loss.
    Darkness and onesojourner like this.
  29. May 25, 2021 at 9:41 AM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Thank you. I am mourning lol!
    jimf909[QUOTED] and FirstGenVol like this.
  30. May 25, 2021 at 9:44 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Darkness likes this.
