Non FFV Rough Cold Start
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by simple tundra 16, Nov 27, 2023.
  1. Nov 27, 2023 at 4:49 PM
    simple tundra 16
    simple tundra 16 [OP] New Member
    North Cackalacky
    2016 Stock 5.7 Tundra
    Vehicle Modifications:
    Hey all, glad to join yall on here as I have used this forum as a guest many times but finally joined.
    Issue: NON FFV, new battery, new spark plugs. When cold, takes 2-3 different tries to get truck to crank. Sometimes just a stumble when it cranks, other times its a real struggle to crank and when it does, get some white smoke and a strong fuel smell. Sounds like my 86' Chevrolet when it cranks. Truck turns over fine, just doesn't fire.
    I've seen many threads on this but with flex fuel trucks, mine is NOT. I am assuming its probably all related between the different motors but the TSB's I have seen are only for the flex fuels, am I missing one? TIA.
  2. Nov 27, 2023 at 5:45 PM
    Where’d ya get the plugs?
    Retired...finally likes this.
  3. Nov 27, 2023 at 6:41 PM
    simple tundra 16
    North Cackalacky
    Toyota dealership & installed.
    edit: the issue was not present before battery/plugs nor did it start right after.
  4. Dec 11, 2023 at 8:16 PM
    padilla_gorilla
    padilla_gorilla New Member
    Mat
    2016 SR5 Brown Tundra
    4.5 in lift on 35's Toyo open country
    Did you ever figure out what the issue was? I'm having the same problem.
  5. Dec 11, 2023 at 8:39 PM
    simple tundra 16
    North Cackalacky
    No, unfortunately I have not. Still struggling in the cold but haven’t really had it looked at either.
  6. Dec 11, 2023 at 9:24 PM
    padilla_gorilla
    Mat
    That's where I'm at. Lol If I find a solution to our problem, I will write back to you on this message board.
  7. Dec 12, 2023 at 6:29 AM
    simple tundra 16
    North Cackalacky
    I appreciate that and I will do the same if I get it figured out.
  8. Dec 12, 2023 at 7:12 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I would probably say battery, what does the sticker say on the battery? or what does the numbers on the manufacturer say? Since "new" batteries may be old by sitting on some counter for 6 months to a year or 2 before being sold. White smoke may be normal as cold weather and hot exhaust will make it more obvious. As for fuel, maybe go somewhere else for gas and drop a bottle of seafoam on there and see if it makes a difference. Also check your coil pack plugs and ensure they're fully seated as well as the bolts holding down the coils. Any chance they become loose, they will bounce around and lose contact and start misfiring. I know you took it to the dealership, but the techs there are human too and depending on workloads they may have overlooked something somewhere.
    simple tundra 16[OP] likes this.
