Non-DOT tire cold vulcanizing
Discussion in 'Wheels & Tires' started by ColoradoTJ, Oct 6, 2019.
  1. Oct 6, 2019 at 4:28 AM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    Tremor F-250, Roush Mustang, Jeep Crawler
    ****Please do not attempt this on DOT tires that see pavement. Off Highway only repairs****
    @COMiamiFan and I had a pretty good time Jeeping the other day until I got a little hairy legged and ripped a sidewall on a tree. This pretty much brought on the suck driving out on a flat 40" tire and caused some significant damage to the tire and beadlock ring.:D
    I was just going to put the beadlock ring in a lathe and take off a "smidgen", but it just isn't worth it anymore. On my next tire purchase, new beadlock rings will be purchased. I cleaned the ring up as much as I could, and this looks 100% better than the before shots.
    I have already done one of these repairs on another tire, and has worked flawlessly.
    Here is a video of the process:
    I'll update this when I finally get this completed.
    TXMiamiFan, daria and Black Wolf like this.
  2. Oct 6, 2019 at 5:32 AM
    Very interesting....
  3. Oct 6, 2019 at 5:50 AM
    Rubberdown
    Hrrrrrmmmm. I didn’t know you could do that. Talk to me about durability and such if the repair. Is it as durable as the surrounding rubber? Is it as hard? Is it going to peel when it’s abraded?
  4. Oct 6, 2019 at 6:23 AM
    I haven’t had any issues with other tires when rubbing up on rocks with excessive throttle.
    Most older people remember hot vulcanizing.
    Black Wolf likes this.
  5. Oct 7, 2019 at 4:55 PM
    And I wait....
    This is the primer before mixing the two compounds. 4F715BD5-C4C1-4563-90DC-919BE835C2BC.jpg
    Rubber installed, now wait for 24 hours @ 70*F OT higher. In my case, the garage will need to be heated.
    After the cure process, I’m sure some of the rubber will need to be ground down to fit the beadlock ring.
  6. Oct 7, 2019 at 6:11 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  7. Oct 26, 2019 at 7:22 AM
    Holds 25 psi and the weight of the Jeep.
    On to the next tire....
    TXMiamiFan likes this.
  8. Oct 26, 2019 at 8:20 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That tire is totally asking for it
  9. Oct 26, 2019 at 8:56 AM
    And I plugged it...:eek2:
