Noisy motor??
Discussion in '2nd Gen Tundras (2007-2013)' started by BigBarney, Aug 2, 2016.
  1. Aug 2, 2016 at 11:00 PM
    BigBarney
    BigBarney [OP] New Member
    Dustin
    2011 Tundra Rock Wariorr
    But, onto other things! So, if you read my other posts, I am curious if this is a noisy motor or is there an actual problem? What can I do to quite her down? Took a video (attached http://youtu.be/cb4L7O6hSlc). Take a look and let me know guys.
    Thanks!
  2. Aug 3, 2016 at 6:10 AM
    Normal
  3. Aug 3, 2016 at 6:15 AM
  4. Aug 3, 2016 at 6:17 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Sounds like a truck. Ain't gonna be a caddy that's for sure. :burnrubber:
  5. Aug 3, 2016 at 6:41 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Which engine do you have? Sounds louder than mine but I test drove another Tundra the other day that sounded just like yours.
    Make sure everything on your EGR system is tight.
  6. Aug 3, 2016 at 8:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Normal. The exhaust manifolds aren't the heavy cast ones, like in times past. They're actually a little thinner and header-like. That's right where you were holding the camera. I remember going from the stock manifolds to headers on my 97 Tacoma and noticing quite an increase in the sound. Also there's a lot going on in the valve train, two cams, four valves/cylinder, injector noise.
    ColoradoTJ likes this.
  7. Aug 3, 2016 at 6:34 PM
    BigBarney
    Dustin
    Thanks for the input guys. I'll stop worrying about it
    Law323 and T-Rex266 like this.
