Noisy bed rattle
Discussion in '2.5 Gen Tundras (2014-2021)' started by HARPER306, Aug 11, 2020.
  1. Aug 11, 2020 at 9:12 AM
    HARPER306
    HARPER306 [OP] New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    Hello all, did some searching and couldn't find a direct answer so..
    When I got my truck one of the first things I noticed (with the back window down) is how noisy the bed is going over rough terrain at lowish speeds. Sounds like the whole bed is just rattling around. Can't remember if the few I test drove prior to this made the noise. Is this common and/or have a simple fix? I've read it could be the tailgate or the leafs, but I don't really have any creaking. Just sounds like the bed is loose in the back or something
    Edit: here is a video of the noise
    https://streamable.com/jv8uly
  2. Aug 11, 2020 at 9:26 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Let me help you out some, and I'll rephrase your question for you...
    So what stereo upgrades do I need to do to avoid hearing anything from the outside world?
    That should fix the problem for ya!!
    And I've not noticed any bed rattle, will listen next time though.
  3. Aug 11, 2020 at 9:32 AM
    HARPER306
    SK, Canada
    Haha been there done that in many a previous vehicle
    It's not something you have to specifically listen for, it's always present with the back window down so if you don't hear it you're probably fine
  4. Aug 11, 2020 at 11:35 AM
    Johnny_B500
    Johnny_B500 New Member
    2020 Tundra TRD Off Road Crew Max - Cement Grey
    Going a bit beyond the bed here but, check rear spare tire and front skid plate for potential rattles/clangs.
    14burrito and Black Wolf like this.
  5. Aug 11, 2020 at 12:16 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  6. Aug 11, 2020 at 12:19 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Check the spare tire chain.
    14burrito and HulkSmurf14 like this.
  7. Aug 11, 2020 at 12:53 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Do you have after market shakles?
  8. Aug 11, 2020 at 1:29 PM
    HARPER306
    SK, Canada
    Will do. Almost certain it's from the rear but doesn't hurt to check any suggestions
    Nope haven't towed anything with er yet
    Will do that tonight
    No sir, however, I have heard they do improve some noises
  9. Aug 11, 2020 at 2:34 PM
    mountainpete
    To be clear, there is a difference between bed squeaks and rattles. Squeaks are a more common issue. Rattles like metal on metal are not.
  10. Aug 11, 2020 at 3:30 PM
    Braveran
    Braveran New Member
    2014 Tundra Sr5 5.7l Blue
    Check your heat shield above your exhaust.
  11. Aug 11, 2020 at 4:51 PM
    HARPER306
    SK, Canada
    Yessir it's definitely a rattle
    Will do
    I'll try to get a vid tonight sometime if this columbus/Tampa game ever ends
  12. Aug 11, 2020 at 4:58 PM
    RyRy12
    RyRy12 New Member
    ‘17 Silver SR5
    Do you still have the factory drop in bed liner? That created some rattling for me similar to what you are describing.
  13. Aug 11, 2020 at 5:21 PM
    HARPER306
    SK, Canada
    No sir bed has no liner yet whatsoever
  14. Aug 11, 2020 at 5:31 PM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Mine does this too. I got no spare tire or chain mechanism to hold a tire. No drop in liner. The only think I can think of is the tail gate moves up and down on the passenger side and or the the rear window bouncing around in the track. But it definitely sounds like a part bouncing around in the box when you hit bumps. I’ve been under truck multiple times and can’t find anything that makes that noise.
    HARPER306[OP] likes this.
  15. Aug 11, 2020 at 5:35 PM
    HARPER306
    SK, Canada
  16. Aug 11, 2020 at 5:36 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Why would this matter?
    Riddle me curious
  17. Aug 11, 2020 at 5:39 PM
    HARPER306
    SK, Canada
    Ya if its just normal bed rattle I don't really care how loud it is as long as it won't be detrimental down the line
    Ted4311 likes this.
  18. Aug 11, 2020 at 11:07 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Well. Aftermarket bushings in the shackles. Of they aren't greased well they will squeak
  19. Aug 12, 2020 at 4:13 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Damn that’s more like clunking than rattling. Sounds like something is loose (spare tire? Exhaust?). I’d try riding in the bed and have someone drive you around to get a better idea of what it is, or just take it to the dealer and let them figure it out!
    Ted4311 likes this.
  20. Aug 12, 2020 at 5:57 AM
    mountainpete
    That’s not a normal rattle. I would schedule a visit to the dealer. It’s a 2020 - let them figure it out.
    Ted4311 likes this.
  21. Aug 12, 2020 at 7:09 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Holy heck. Definitely keep the updates coming. Gonna ride in the bed of my truck after hearing this video.
  22. Aug 12, 2020 at 7:13 AM
    PJR202
    PJR202 New Member
    The noise you're hearing is actually a cable bumping into the back window glass, down inside there when the window is down. You can put a piece of dynamat or something in there. Google around and you'll find a fix. I saw one somewhere a while back. I thought it was the glass itself and it really seemed like a bad design, but it's a cable that moves with the glass as I understand it, and when it's compressed it slaps the window.
    edit: I think it's bumping into the sheet metal instead of the glass. I forget. I would give you a link to what I found but it took a while and right now I don't see it. I think they just opened it up and put dynamat in the spot where it was making contact.
  23. Aug 12, 2020 at 7:24 AM
    HARPER306
    SK, Canada
    Being a HD mechanic by trade I tend to like to give this sort of stuff a shot myself but if that doesn't work she'll be goin in for sure
  24. Aug 12, 2020 at 8:18 AM
    PJR202
    PJR202 New Member
    See my above post. I think it'll help you out.
  25. Aug 12, 2020 at 8:30 AM
    HARPER306
    SK, Canada
    Ya as far as interior disassembly etc is concerned I have no interest in messing with that haha
  26. Aug 12, 2020 at 8:40 AM
    PJR202
    PJR202 New Member
    Can't blame you there. I'm pretty confident that's the issue because that's exactly what mine sounds like. I just let it be...for now at least.
  27. Aug 16, 2020 at 4:12 PM
    PinnacleX
    PinnacleX New Member
    Bart
    2020 TRD Off Road
    YUP got the same thing Im in Manitoba just picked up my 2020 dont even have 200 KM on it and its rattling so bad just like that and the warped dash by the vent, Im not thrilled with this Truck ATM. Everyone is throwing things out there but have you taken the tailgate off? I haven't since I need 2 people,then you have to disconnect that camera cable, take it for a ride and make us another video. lol
  28. Aug 16, 2020 at 5:55 PM
    PinnacleX
    Bart
    2020 TRD Off Road
    Yes sir you are correct!! I just asked my buddy a Toyota Tech. They need to take out the entire back to get to the window and fix it however the tech sees fit. Its funny I never had these issues on my 2008 Limited.
  29. Aug 17, 2020 at 7:11 AM
    PJR202
    PJR202 New Member
    I haven't looked, but I wonder if a guy could fish the cable out with a coat hanger and attach something to it there. I don't understand how Toyota could let soemthing that glaring go.
  30. Aug 17, 2020 at 10:28 AM
    PinnacleX
    Bart
    2020 TRD Off Road
    no way of doing that, you have to find a way to stabilize it like on the previous gen
