Noisy 6112s...any advice?
Discussion in 'Suspension' started by Boris7k, Oct 3, 2020.
  1. Oct 3, 2020 at 4:41 PM
    Boris7k
    Boris7k [OP] New Member
    2019 TRD Off-Road
    Shell, tint, 6112s at 1.9, 5160s with Icon expansion pack, Cooper ST Maxx LT275/70R18, RCI front skid plate
    So, I installed a set of 6112s about a year ago and I've been noticing a clunk or creak when entering parking lots and driveways with gutters, sounds like something shifting and returning as the suspension cycles. I used the instructions I found here, no problems during installation. They were assembled by Boss 4X4 with a shim on driver's side. I have checked torques numerous times, even loosened and retorqued with jack under LCA, sway bar and bushings have been loosened and retorqued. Planning to loosen UCA bolts and retorque them next, any other ideas would be appreciated.
  2. Oct 6, 2020 at 3:37 PM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    What side of the truck is the clunk on?
  3. Oct 6, 2020 at 3:48 PM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    ColoradoTJ likes this.
  4. Oct 6, 2020 at 3:51 PM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
  5. Oct 6, 2020 at 6:50 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I was the one in one of the posts... check your skid plate, check all your clearances. Check your LCAs and bushings, check your steering stops.
  6. Oct 7, 2020 at 9:55 AM
    Mr. White
    Mr. White Poco Loco
    San Antonio
    2020 Family 4x4
    I had the 6112's on my Tacoma and developed the same clunk noise. It bothered me and I tried fixing it for a while, but never found it. Odd that it was fine for a year and then started making noise. Mine was coming from my drivers side.
  7. Oct 7, 2020 at 11:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Get a paint pen and mark your alignment cam bolts and check them again after a couple days to see if they moved.
  8. Oct 7, 2020 at 12:09 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    OP post some pictures of the suspension
  9. Oct 8, 2020 at 5:12 AM
    Boris7k
    2019 TRD Off-Road
    WINNER! I installed an RCI skid plate back in May, didn't even occur to me that could be the culprit. I loosened the two aft nuts enough to slip some plastic spacers in and tightened the nuts back down, backed out of and into the driveway and could not make the noise again. Thanks for all the help, I love this place!
    DeesCrewMax[QUOTED] likes this.
