Noise when wheel spins
Discussion in 'General Tundra Discussion' started by Nodlenor, Dec 18, 2016.
  1. Dec 18, 2016 at 6:20 PM
    Nodlenor
    Nodlenor [OP] New Member
    Ronald
    2010 Black Tundra TRD SR5
    I took my Tundra out in the snow today to see how it performs. I noticed when one of the wheels spins there is a noise in the drive train. Otherwise it did really well on the slick stuff. We had ice with about 3 or 4" of snow on top of it. I'm still not used to the touchy throttle but it seemed to have good traction even with the not so great tires that came on it. Is this noise common with the limited slip diff. or should I be concerned. It seemed to be coming from the front whether in 4wd or 2wd. Hard to describe it but it was intermittent and kind of a slapping or scrapping sound. Any ideas?
  2. Dec 18, 2016 at 6:22 PM
    U mean traction control kicking in?
    Relentless and MotoTundra like this.
  3. Dec 18, 2016 at 6:22 PM
    Nodlenor
    Ronald
    Probably!
  4. Dec 18, 2016 at 6:36 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Sounds like a clicking vibrating sound? Def traction control. Probably getting some flashing and beeping going on in the cabin as well
  5. Dec 18, 2016 at 7:49 PM
    Nodlenor
    Ronald
    That is probably it but I haven't noticed any flashing or heard any beeping. I hope it is normal, not an indication of some upcoming problems.
  6. Dec 18, 2016 at 7:53 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    If it's traction control, which is what it sounds like, that's totally normal. Kind of sounds like ABS kicking on.
    When that happens the Traction control icon should flash on your dash.
    Our limited slip system works by an ECU applying the brake to the spinning wheel, therefore forcing power to the other side.
  7. Dec 18, 2016 at 8:06 PM
    Nodlenor
    Ronald
    Thanks, I'll look for a light the next time it happens. I sure hope that's what it is. I wasn't expecting something like that when I first heard it and it alarmed me. Thanks again, that eases my mind somewhat.
    MotoTundra likes this.
  8. Dec 18, 2016 at 8:15 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    What you are describing seems to me like a normal functioning traction control system, but yes, I would look for the flashing light.
    Should flash when you slip and make a weird grinding/pulsating noise, hard to describe.
  9. Dec 19, 2016 at 4:07 PM
    Nodlenor
    Ronald
    I drove my Tundra on the icy roads today and when it spins a wheel a light does com on. I didn't notice that yesterday. I'm relived to know the noise I hear is normal and not something that is going to make my bank account suffer in the near future. Thanks again to all who responded and helped relive my concerns.
    MotoTundra and Lowcountrytj like this.
  10. Dec 19, 2016 at 4:55 PM
    Since traction control almost got me stuck (again) in wet slush/ice (yes, in 4WD) I've begun turning traction off (just one push for traction control completely off in 4HI) when in 4wd. I found by shutting this off in snow, it feels safer by not reducing engine power allowing me to get onto the street safely.
    NewImprovedRon, MotoTundra and 831Tun like this.
  11. Dec 19, 2016 at 6:29 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Glad to hear, I didn't doubt that Tundra one bit!
    T-Rex266 likes this.
  12. Dec 20, 2016 at 10:13 AM
    Nodlenor
    Ronald
    Sean, I tried turning off the traction control while in 4wd and I agree I seem to have more/better control or at least a better feel. Thanks for the tip!
    T-Rex266 and NewImprovedRon like this.
  13. Dec 20, 2016 at 10:26 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I hate traction control. It cuts power just when you need it. I have snow tires on the truck and find that turning off the traction control works better when you are doing around town driving (especially when you are trying to accelerate from a stop). However, when on the highway, I leave it on as a safety margin.
    Crewmax Chris likes this.
  14. Dec 20, 2016 at 1:42 PM
    Also a tip: Never walk alone in dark alleys at night.
    You're welcome.:D
  15. Dec 20, 2016 at 1:43 PM
    gdiep
    Syracuse, New York
    Look both ways before crossing the road.
    T-Rex266[QUOTED] likes this.
  16. Dec 20, 2016 at 4:39 PM
    Nodlenor
    Ronald
    If you lived in an area like where I live you wouldn't need to worry about dark alleys. Also the streets aren't that busy, but I look anyway. But those are good tips.
