Noise(s) coming from under my 2008. Been trying to track it down for over a year.
Discussion in '2nd Gen Tundras (2007-2013)' started by ryanwilson50, Apr 18, 2023.
  1. Apr 18, 2023 at 6:32 PM
    ryanwilson50
    ryanwilson50 [OP] New Member
    Ryan
    2008 Two-tone Tundra Crewmax
    6” ProComp Lift 35” Tires
    I’ve been trying to track a rattle/pop noise down under my truck since I purchased it. I’ve read extensively through forums and can not find an answer. The best way to describe the rattle would be similar to a failing CV axle. However I know it isn’t the CV axles or suspension components as I refreshed the whole front end (struts, CV axles, UCAs and LCAs, ball joints, inner and outer tie rods). It sounds like the noise comes from underneath the truck and it is intermittent. I will randomly hear the noise with sometimes one pop/click (metal noise) or sometimes multiples clicks/rattles (also metal noise). The part that has made it so hard to trace down is the fact that it is intermittent and I have not found a forum that describes the same noise. I know it is not a heat shield rattle as it sounds more cyclical and not as “tin can” as a heat shield would produce. The only thing I can think of as a possibility at this point would be U joints. My trucks has 135k miles and as far as I know they are the original U joints. Greased them about a week ago and my truck drives noticeably better but still has the noise. Any help is much appreciated.
  2. Apr 18, 2023 at 7:20 PM
    chrisf111
    chrisf111 New Member
    Check your parking break linkage. That was causing some noise for me on bumpy roads a while back. Doesn't really sound like what you're describing but it's worth a shot.
  3. Apr 18, 2023 at 7:45 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Sway bar end links?
    blackdemon_tt likes this.
  4. Apr 18, 2023 at 8:38 PM
    ryanwilson50
    Ryan
    I just adjusted the parking brake cable last week to tighten up the parking brake. The noise sounds more cyclical than a rattle caused by bumps
  5. Apr 18, 2023 at 8:39 PM
    ryanwilson50
    Ryan
    I have some new end links I’m putting on tomorrow which could fix the pop noise but don’t think the cyclical rattle could be caused from sway bar links
  6. Apr 18, 2023 at 8:49 PM
    Skid plate? Cat shields?
    shannon likes this.
  7. Apr 18, 2023 at 9:24 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    On your firewall passenger side is a bracket. I forget what it holds but you have to move it to change spark plugs I think - or something back there. Make sure that thing is tight to the firewall or it will make a noise as you describe.
    ryanwilson50[OP] likes this.
  8. Apr 19, 2023 at 3:44 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Go to a parking lot with a lot of room, do some full lock circles at low speed in both directions and see if it produces the noise...
    If you don't know what make parts the garage used to replace your front end your problem may be front end still.
  9. Apr 19, 2023 at 4:45 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Brake backing plates?
  10. Apr 19, 2023 at 9:07 AM
    ryanwilson50
    Ryan
    Seems too cyclical to be a rattle from a shield. Also don’t have skid plates on mine
  11. Apr 19, 2023 at 9:08 AM
    ryanwilson50
    Ryan
    going to check this out today. However the noise sounds like it comes from below the truck
  12. Apr 19, 2023 at 9:09 AM
    ryanwilson50
    Ryan
    I actually did all the front end work myself. The CV axles I got were just generic brand from Advanced Auto. However I would think there would’ve been a gap of me not hearing the noise after installing the new CVs and having it come back. I noticed it as normal after installing the CVs
    TheBrit[QUOTED] likes this.
  13. Apr 19, 2023 at 1:24 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I would go with sway bar end links. When mine were loose on another vehicle. It would sound cyclical and was intermittently. I could shake the entire car and would hardly get a squeak. Once I went over a slight bump, or big bump it would sound like I was rolling a tin can around. My mistake is I hit them with an impact and called it a day. In fact impact is good to remove them, but not instal them. You will need to hold them with a wrench or allen key and go manual.
  14. Apr 20, 2023 at 2:27 AM
    rock01
    rock01 New Member
    Rich
    2006 Tundra SR2 2wd
    front hitch, timbrens, camper shell
    Bought my ex-wife a 2012 Tundra with 60k on it (before things went south) and the stock OEM brake pads were terrible. They would bind up if switching to reverse and make all sorts of noise. I changed out the pads (only) and the noise went away. I agree with finding an empty parking lot. Roll all the windows down and drive around. I like to put it in neutral and kill the engine and coast, too. Great for diagnosing driveshaft/wheel bearing noises separately from the engine.
  15. Apr 20, 2023 at 8:47 AM
    ryanwilson50
    Ryan
    I would think if it were brakes it would be more frequent. However, there are some days I don’t hear it at all and others that I hear it at various speeds. Will take a look at the brake pads though!
  16. Apr 21, 2023 at 7:16 AM
    Landodnal
    Landodnal New Member
    Ryan
    2008 Toyota Tundra Limited Slate Grey 4WD
    2" Leveling Kit
    Here are my two thoughts. First thing I'd do is check the tightness of the two bolts that hold the brake caliper brackets on. I've had mine loosen which lets the caliper shift every time you brake which makes a click/clunk noise. I doubt this is it, but it's worth checking. It's a quick fix if so.
    The second thought I have is: the needle bearing on the driver's side front differential. This isn't the bearing out in your wheel hub where the CV axle ends, it's the bearing inside the differential where the CV axle first inserts when you install the new one. This bearing can go bad and cause clicking noises and vibration as you roll. Mine is currently clicking. The fix is to replace the bearing with a bronze reverse clamshell bushing from ECGS. This eliminates the needle bearing. I'm actually purchasing one as I write this. I'll try to make a post if this fixes my issues.
    Hope this helps. Good luck troubleshooting your issue!
  17. Apr 21, 2023 at 11:47 AM
    ryanwilson50
    Ryan
    Thanks for the info!! Would you hear that needle bearing rattle even if not in 4WD? Is there also a needle bearing in the rear diff?
  18. Apr 21, 2023 at 11:49 AM
    ryanwilson50
    Ryan
    I almost forgot. I actually already replaced that needle bearing in my tundra last summer. If there’s one in the rear diff that could be a possibility.
    Landodnal[QUOTED] likes this.
  19. Apr 21, 2023 at 6:05 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Check your exhaust hangers.
