Noise going over bumps after lift install
Discussion in 'Suspension' started by tundra 4917, Jun 21, 2020.
  1. Jun 21, 2020 at 11:06 AM
    tundra 4917
    tundra 4917 [OP] New Member
    Art
    Tundra trd pro 2020
    Ready lift
    Had a ready lift installed on my 2020 tundra trd pro by 4 wheel parts now Everytime I drive over a bump drive in or out of my garage I hear a noise coming from the suspension 4 wheel parts is stumped and can't find the issue. Any suggestions or someone having the same issue?
  2. Jun 21, 2020 at 11:08 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Could be the skid plate rubbing against the frame.
  3. Jun 21, 2020 at 11:11 AM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Did you install aftermarket uca? Diff drop?
    I'd take that spacer lift off personally. Your CV angles are probably terrible now and your balljoints are being way too stressed.
    I've used a spacer lift on a previous 4runner before and learned the hard way, I'll never do it again. If you want a huge lift, it's gonna cost you in the long run
    AccuTune Offroad likes this.
  4. Jun 21, 2020 at 11:20 AM
    tundra 4917
    Art
    Tundra trd pro 2020
    Ready lift
  5. Jun 21, 2020 at 11:21 AM
    tundra 4917
    Art
    Tundra trd pro 2020
    Ready lift
    Well they checked that and said that wasn't the issue.
  6. Jun 22, 2020 at 6:16 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Which ready lift? What kind of noise? (Squeak, thud, grinding?)
  7. Jun 22, 2020 at 6:34 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    I get a thump on full lock either way. And on a deep bump i hear a bong drop like it was fully extended. On my Ready lift 3/2. Looking to replace mine
  8. Jun 23, 2020 at 5:56 PM
    Toytec Alumas and shackles! Rides alot better than spacers.
  9. Jun 24, 2020 at 9:42 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    ^ This. With spacer lifts, we've seen the spring hitting the control arm at full droop. Lots of other issues with spacer lifts as well.
    saybng and bdpeelgren like this.
  10. Jun 24, 2020 at 9:50 AM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Why pay such a premium for a Fox suspension set up and then change it with a cheap ready lift :monocle:
  11. Jun 24, 2020 at 10:29 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    If your referring to the ReadyLift Pro +2, I have the same lift on the front of the truck but a 1.5" shackle w/ 1" block on the rear and hear nothing more than the usual before the lift.
  12. Jun 24, 2020 at 10:30 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Aren't diff drops not neccessary for under 3", actually would cause more harm then good?..
  13. Jun 24, 2020 at 10:40 AM
    NikNoid
    NikNoid New Member
    Check your front swaybar mounts. I had my Billstein kit installed and they left one of the front swaybar mounts loose. Easy enought to check it by crawling under the truck and banging around with a rubber mallet. Soon as I hit the swaybar... bingo problem found.
  14. Jun 24, 2020 at 10:41 AM
    AccuTune Offroad
    El Cajon, CA
    We don't see a need for them no. Just need more info from the OP, however if the shop that installed it cannot see where this noise is coming from... its going to be hard to diagnose via the interwebs
    saybng[QUOTED] likes this.
  15. Sep 20, 2021 at 5:50 AM
    @TUNDRACRUZ
    @TUNDRACRUZ New Member
    2019 Tundra TRD off-road
    3/2 ReadyLIFT
    I’m having a similar issue on my 2019 Tundra after the 3/2 ReadyLIFT. Squeaky noise in the back and a metal clunking noise in the front, all when going over bumps. Anyone figured this out yet?
  16. Sep 20, 2021 at 5:52 AM
    bdpeelgren
    Round Rock, TX
    Fixed mine by removing and selling it.
    No shop could fix all the noise I was getting from my 3/2
    Sunnier and @TUNDRACRUZ[QUOTED] like this.
  17. Sep 20, 2021 at 6:02 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    Man that would suck for me. It just baffles me because I know people with Tundras that have 3/2 ReadyLIFTs with no issues. Even Gearrunner on YouTube. This is a bummer. But thanks for your help.
  18. Sep 20, 2021 at 6:29 AM
    bdpeelgren
    Round Rock, TX
    From what I’ve gathered, some trucks don’t have issues, some do. By the time you have shops look at it and try to figure out what’s going wrong you might as well have bought a suspension lift and not a spacer lift. I had hell with mine.
    Also without aftermarket UCAs you will always get outside tire wear. No matter what the alignment says.
    @TUNDRACRUZ[QUOTED] likes this.
  19. Sep 20, 2021 at 6:59 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    Maaan, real good to know. I think it might be my sway bar. I’m taking it to the shop today. Thanks again for your help.
