Noise from overhead interior light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hoosier33, Jan 8, 2024.
  1. Jan 8, 2024 at 7:49 PM
    Hoosier33
    Hoosier33 [OP] New Member
    2019 Cement Tundra Limited
    Anyone have any experience with a rattle noise coming from the overhead interior light? Almost as if there is double sided tape that has lost its stick that helps adhere it to the ceiling.
  2. Jan 8, 2024 at 10:00 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The front one or the rear one?
    Either way, there isn't any double-sided tape holding in place.
    They are held in place by screws (the front) and plastic clips (the rear).
    Check the screws on the front one and the clips on the rear one.
    Have you ever replaced the bulbs with LED bulbs?
    Could be the reflector in either light rattling, but doubtful..
    Good luck..
  3. Jan 8, 2024 at 11:30 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Ghost in the machine :monocle:
  4. Jan 9, 2024 at 2:58 AM
    Hoosier33
    It is the rear light. Possible the screws are loose. I will check that.
