Noise from driver wheel
Discussion in '2nd Gen Tundras (2007-2013)' started by RockWarrior2k10, May 11, 2020.
  1. May 11, 2020 at 12:16 PM
    RockWarrior2k10
    RockWarrior2k10 [OP] New Member
    2010 Tundra Rock Warrior
    Bull bar with led light bar, 35in tires, more to come.
    There is a constant click noise coming from my front left (drivers) wheel area. It sounds like a rock stuck in the tread but I cleaned out the treads and it's still clicking. No matter if I go fast or slow. Any ideas? I'm hoping it's not the bearing..also there is a lot of brake dust on the rim today..help please lol
  2. May 11, 2020 at 2:12 PM
    CallMeD
    CallMeD New Member
    Check your tires for nail/screw. Also check to see if you ran over some gum/something sticky...might seem unlikely, but it happened to me not so long ago.
  3. May 11, 2020 at 5:10 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Jack up your driver side wheel and see if you can duplicate the noise by rotating the wheel. If you can, it's probably some interference issue in the brakes on that wheel, continue turning the wheel to locate the noise. If the noise isn't present with the wheel off the ground, then it's probably a foreign object in the tread that you've missed.
  4. May 11, 2020 at 6:14 PM
    RockWarrior2k10
    I've cleaned out the rocks but it's still there. Gonna jack it up and try that. Thank yall for the advice. How likely would it be that the bearing needs replacing?
  5. May 12, 2020 at 5:34 AM
    JohnLakeman
    There is very low probability it's a wheel bearing in my opinion. It is unlikely that bearing failures will be limited to a single point defect that provides a once per revolution signal. A singular defect in a roller bearing creates failure debris that quickly spreads damage to all rollers and races even as it becomes audible. That's why the noise from failing wheel bearing can typically be described as a "rumble".
  6. May 12, 2020 at 5:45 AM
    Vizsla
    Vizsla 2 = 2.5
  7. May 12, 2020 at 6:37 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Whenever I had that happen on any car it was one of two things- something in the tread like a rock or screw or....a loose wheel weight.
