Noise from dash when I touch gas pedal
Discussion in '2.5 Gen Tundras (2014-2021)' started by Creepbam, Mar 3, 2022.
  1. Mar 3, 2022 at 6:10 PM
    Creepbam
    Creepbam [OP] New Member
    2020 SR5 4x4
    20 Crewmax 4x4, I'm getting a thud sounds coming from the dash area when taking off from a stop. It's not the ABS check. This happens everytime I take off. It sounds like it's in the dash kind of like a AC door or something. Noise doesn't happen on bumps or once I'm moving. Only the intails gas press from a red light etc.. Any ideas? Thanks
  2. Mar 4, 2022 at 2:15 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Check your glove box. The manual or anything else in there can shift when you take off and it will in fact make a thud sound. Had that happen myself until I figured out what it was.
    If that is not it, you are going to need to try and isolate what area the sound is coming from. Upper, left, right, etc. Post what you find and we will help best we can.
    HulkSmurf14 likes this.
