Noise concern
Discussion in '2.5 Gen Tundras (2014-2021)' started by CoreysSilverTundra15, Oct 13, 2024.
  1. Oct 13, 2024 at 9:51 AM
    CoreysSilverTundra15 [OP] New Member
    Can anyone tell me what they believe this noise to be from? I have changed the Idler/Tensioner pulley and the serpentine belt. It started making this sound after I replaced them. I used Dayco pulleys but it was an autozone belt I used which I think could possibly be the issue but I don’t want to keep throwing money at it and not fix it. Could any of you guys please help me figure this out? I’m going to try to post it this won’t let me upload a video from a phone.
  2. Oct 13, 2024 at 9:54 AM
  3. Oct 15, 2024 at 6:14 PM
  4. Oct 15, 2024 at 7:13 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Toyota is one of those companies where sometimes you gotta stick with oem parts. I’ll just leave it at that.
  5. Oct 16, 2024 at 3:11 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    On the 5.7’s, it’s VERY easy to route the belt wrong. If you haven’t done it already, triple check your belt routing especially by the alternator/tensioner area.
  6. Oct 16, 2024 at 7:16 AM
    I’m going to check it after work today, my dad and I did the job together and I believe we could have routed it wrong.
  7. Oct 16, 2024 at 7:22 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    It’s so easy to mix it up on this engine. Don’t ask me how I know.
  8. Oct 16, 2024 at 9:09 AM
    It’s crazy because it’s always on the passenger side and it sounds like it’s near the top near the top two left pulleys.
  9. Oct 16, 2024 at 9:42 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I had to replace my 2020's alternator at 60K as the bearing went and it was making quite a bit of noise, more than yours. I used a stethoscope to verify that it was the alternator and not the power steering, as they are jammed together.
  10. Oct 16, 2024 at 5:11 PM
    d33pt
    d33pt New Member
  11. Oct 16, 2024 at 6:02 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
  12. Oct 17, 2024 at 6:39 AM
    Thanks for the diagram, didn’t have time yesterday evening. Checking it out tonight and will update yall here.
  13. Oct 19, 2024 at 7:05 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Any update to your issue? Did you check the belt routing?
  14. Oct 19, 2024 at 7:11 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Alternator's bearings don't sound like that.
    What happened to yours, by the way? Was it submerged?
    Troysbama likes this.
  15. Oct 19, 2024 at 7:16 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In my experience with other car brand, Contitech belts were a tiny bit shorter than the original (made by Gates), and they did not stretch as well. The part number was correct, but it barely slid over the last pulley, the tensioner was always maxed out, and the next thing that fails was usually steering pump. Unless the belt itself fails sooner.
    If it's something you have to replace every few years, there's no economical sense to use cheaper parts in most cases.
  16. Oct 19, 2024 at 1:44 PM
    I sprayed water on it at work while it was running and the squeak stopped, so I went with a Dayco belt which fits slightly tighter than the duralast does. After changing the belts my issue went away. $64 Dayco belt beats the $33 duralast belt.
  17. Oct 19, 2024 at 3:41 PM
    yakeng
    No, it’s likely COVID supply chain issues and bad manufacturing. Unfortunately not the only issue I’ve had.
    Just replaced two bad door checks last week. I have a thread somewhere of the numerous issues I’ve had. I’m at least a couple grand in fixing problems on my truck. Pretty sad for a 2020.
  18. Oct 29, 2024 at 4:01 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I think it is Toyota these days. Maybe US Toyota. Both my pre-COVID Tundra and post-COVID Sequoia have small issues, like cosmetic defects or malfunctioning something that I don't use, like sun roof. European car would fail QA right on assembly line. But. As long as I don't need to spend days laying under them, I don't care. It takes me to the woods, it takes me out of the woods, I'm happy.
