No voltage energizing C/OP relay - fuel pump system
Discussion in '1st Gen Tundras (2000-2006)' started by BEddiet, Dec 24, 2019.
  1. Dec 24, 2019 at 7:54 AM
    BEddiet
    BEddiet [OP] New Member
    Barry
    2004 Tundra V8 4wd 4 door
    Hey-
    2004 Tundra full cab v-8 --- Turn no-start condition led me deep into diagnostic hole, fuel pump itself can work when jumped direct to positive battery cable via Fuel Pump relay socket.... relays and fuses themselves check out ok with bench testing.... where I end up is that power does energize the EFI relay with ignition on, but does NOT energize the C/OP relay... schematics I see online seem to indicate power comes from same source to energize both the C/OP and EFI relays, but it is not present at C/OP when I check voltage on the low-side sockets.... if I remove the C/OP relay and jump the switch side sockets is starts right up and runs. Anyone have ideas on where the failure is? I have tested and interchanged relays so it is not a failed relay in the C/OP socket.... ALSO -- If I need to run for 45 minutes at a time and plow my driveway with C/OP jumped is that a problem? THANKS FOR YOUR HELP !!!
  2. Dec 24, 2019 at 9:53 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Have you verified that the ground circuit is good for the relay? I don't see a problem running the truck temporarily with a jumper wire just make sure to put a fuse in it to protect your electrical system.
    BubbaW likes this.
  3. Dec 24, 2019 at 10:56 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Does your truck have any kind of alarm system??
    PCJ likes this.
  4. Dec 24, 2019 at 11:35 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    The only thing a relay does is switch a high current load with a low current source. I.E. say a 30A pump can be switched with a 2A signal circuit. So as long as you jump the correct terminals and make solid contact you should be fine.
    Also calling @BubbaW for a schematic.
    BubbaW likes this.
  5. Dec 24, 2019 at 11:45 AM
    BEddiet
    Barry
    @TX-TRD1stGEN -- Thanks for the response - Yes truck has an alarm system from factory - ... It works because this AM I went to lift the popped hood with doors locked and the alarm blew on until I unlocked the door.
    @PCJ - Thanks for the idea -- no I have not checked ground circuits, not sure where/how wires might run to do that and it is way too cold up here in CT to spend too much time taking fuse boxes out or testing wires.... HOWEVER you give me an idea, that being there should be one low-side terminal in the C/OP socket with direct continuity to a low-side terminal in the EFI relay socket -- easy enough to identify -- then with ignition on and EFI relay in test voltage from the common C/OP socket to an outside ground and find 12 volts.... which would mean the other C/OP socket would be missing ground. I might then hard-wire a ground to a wire slipped in that C/OP terminal with the relay inserted and it might work... I would still consider that temporary until such time I could adequately search wiring for a problem.
  6. Dec 24, 2019 at 11:53 AM
    BEddiet
    Barry
    @bmf4069 - Thanks, yes I understand the workings -- I just worry that the lack of power where it is supposed to be in the low-amp circuit leaves other unknown problems or glitches to occur -- Hopefully @BubbaW can verify the low amp current interruption as non critical at that part of the circuit chain
  7. Dec 24, 2019 at 12:15 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Wish I could offer anything but We are out of town and grandkids are using Paw for a punching bag. Be late evening before we get home and look up anything . Feel confident others can offer up FSM elec schem until then....Merry Christmas all
  8. Dec 24, 2019 at 12:47 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    The c/op (5-3 )only closes when the starter or engine is cranking.
    Five is incoming, 3 is it too fuel pump.
    Point 2 should show 12v to ground when ignition is on.
    Point 1 is controlled by ecm.
    bmf4069 likes this.
  9. Dec 25, 2019 at 9:00 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Hope all are having a Merry. Will await further input from OP and with all the good info provided by everybody(grounds mentioned, relay current source, pin out from schematics) hopefully we will have happy ending.
    One question that I keep asking myself is, nothing about a MIL code was mentioned by OP ? Shouldn't an open or short in a fuel pump relay circuit throw a code....P0230 ?
    Somewhat basic but thought I'd go ahead and offer a few things. I have provided a pic showing 2 things....proper polarity on meter(red lead pos) and ~12vdc present at C/OPN(circuit opening relay) with key in Start position but not started. Along with the pics shown by @TX-TRD1stGEN and along with the below Fuel Pump Circuit description, the Crankshaft Position Sensor could also be an issue.....Tr1(triac) has to be triggered that sends chassis ground output at FC of ECM to Circuit Opening Relay(C/OPN). That's all I got, family showing up for more Christmas celebration :santa:
    https://f01.justanswer.com/El_Jared/cd1fed9f-1a7e-4be3-8df7-8b93f5754f9c_tota+fuel+pump+circuit.pdf
    hammeron and TX-TRD1stGEN like this.
  10. Dec 27, 2019 at 4:50 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Did you get this fixed yet? @BEddiet
  11. Feb 5, 2021 at 6:52 AM
    WadeT64
    WadeT64 New Member
    Toyota Tundra 2007 Crew Max
    What was the solution here? I am having the same issue with my 2007 Toyota Tundra 2007 Crew Max
  12. Jun 23, 2023 at 2:15 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    What happened with this truck?
  13. Jun 24, 2023 at 11:12 AM
    @BEddiet was last seen in October 2022, not sure they're still around.
