No turn signals, windows, acc, or courtesy lights
Discussion in '2nd Gen Tundras (2007-2013)' started by Dcart32, Aug 9, 2023.
  1. Aug 9, 2023 at 6:36 PM
    Dcart32
    Dcart32 [OP] New Member
    2011 tundra 4.7L 2wd ext cab
    I needed to change the expansion valve for the a/c system so to make then easiest access I pulled the dash.
    expansion valve swap went fine no i have lost power to all windows, the courtesy lights, accessories outlets, turn signals and hazards
    i have went through all the fuses several times, tested all my continuities for grounds and ohm tested all my relays and am at lost
    any help is greatly appreciated
  2. Aug 10, 2023 at 1:50 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Hate to ask but to make sure, you went through both fuse boxes right? Engine and Interior?
    I assume the alternator is not charging the battery when the truck is running either?
