no trailer running lamps 2010 tundra
Discussion in 'New Member Introductions' started by Rich R, Dec 16, 2018.
  1. Dec 16, 2018 at 8:28 AM
    Rich R
    Rich R [OP] New Member
    ok i have no trailer running lights
    the 30 amp fuse under the hood was blown so i replaced it, still no running lights at hitch plug i have signal and brake lights, So there is the blue fuse relay in the fuse box so i checked this out
    with a test light and i found no power in the block where this relay plugs in
    so my question is what feeds this blue relay type fuse
    Pinay likes this.
  2. Dec 16, 2018 at 8:30 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
    Pinay likes this.
  3. Dec 16, 2018 at 8:37 AM
    Welcome
    Pinay likes this.
  4. Dec 16, 2018 at 8:39 AM
    Rich R
    hi from Mn.
    Pinay likes this.
  5. Dec 16, 2018 at 9:20 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  6. Dec 16, 2018 at 11:10 AM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    @LOTSOFTOYS is the forum's certified Toyota mechanic. He might be able to shed some light on this issue your having. Welcome to the family
    Pinay likes this.
  7. Dec 16, 2018 at 11:37 AM
    Rich R
    thank you
    Pinay likes this.
  8. Dec 16, 2018 at 12:58 PM
    Welcome from Texas
  9. Dec 16, 2018 at 1:33 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    @NewImprovedRon is very knowledgeable on wiring, he might be able to help
    rons23, Pinay and Rich R[OP] like this.
  10. Dec 16, 2018 at 4:11 PM
    Rich R
    yep key on , with lights on and also w/lights off , swapped out relay w/fuel pump relay
    there is just no juice there
    Pinay likes this.
  11. Dec 16, 2018 at 4:29 PM
    Rich R
    everything works fine , i just bought this truck and went to hook up the trailer and no running lights,so thats when i found the 30 amp fuse thinking that would be the fix , not so
    then i took apart trailerwire harness at the hitch there is no juice for running lights at all back there, every fuse is fuse block under the dash and under the hood check out good
    Pinay likes this.
  12. Dec 16, 2018 at 4:34 PM
    Rich R
    my next thought would be to remove the fuse block under the hood and check the wire going into that relay , i started to take it apart but i'm not sure thats a good move
    Pinay likes this.
  13. Dec 16, 2018 at 4:39 PM
    Rich R
    thank you
  14. Dec 16, 2018 at 5:14 PM
    Rich R
    yep just triple checked all fuses all good , the only i could't check was the 30 amp #27 under the dash , but thats for p/w and they work
  15. Dec 16, 2018 at 5:19 PM
    Welcome from Ohio! Wish you luck on finding the problem.
  16. Dec 16, 2018 at 5:23 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    I had this exact same problem quite awhile back and couldn't figure it out for the life of me. Then I found out there are actually 2 fuses to concern yourself with. Don't remember which one of the 2 were blown but once I replaced it I was GTG.
    If you haven't done so already, make sure you check them both.
    Oh! Welcome from AZ.
    rons23 likes this.
  17. Dec 16, 2018 at 5:31 PM
    Rich R
    yes all are good
  18. Dec 17, 2018 at 1:59 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
    Pinay likes this.
