No trailer lights 2000 tundra 4x4 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by Confusedboathauler, Aug 24, 2023.
  1. Aug 24, 2023 at 8:35 PM
    Confusedboathauler
    Confusedboathauler [OP] New Member
    Morris
    2000 Tundra 4x4 4.7
    I'm very lost, checked main fuse ( tow package equipped) replaced the flat 4 plug all new wiring and lights on trailer that work correctly ( CHECKED WITH OTHER POWER SOURCE) , NO POWER TO CONNECTOR ON TRUCK ? Any suggestions?
  2. Aug 25, 2023 at 2:01 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Was there power at the fuse?
  3. Aug 25, 2023 at 4:25 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The 4 pin connector should plug into a 6 pin connector a short distance under truck Do you have voltage at the 6 pin connector ?
    Are you having any issues with any other systems since trailer circuit is part of other circuits covered by approx 5 fuses.
  4. Aug 25, 2023 at 4:40 AM
    Confusedboathauler
    Morris
    2000 Tundra 4x4 4.7
    No voltage and no other system issues. All fuses are good in both fuse panels.
  5. Aug 25, 2023 at 6:55 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    We can only go by what you tell us and can only assume you have double checked your self, especially your voltage readings at the 6 pin connector.
    Given the 6 pin connector I mentioned above is part of the Frame Harness, it's definitely odd that you did indeed not have no voltage there.
    If you are positive there is no voltage at T 6 connector, and "no other system issues. All fuses are good in both fuse panels", my next suggestion is to look at the 12 pin connector(BB1) under the drivers seat.
    That connector is the feed for the Frame Harness that feeds the connectors shown below.
  6. Aug 25, 2023 at 7:08 AM
    I didn't think the older 1GTs had tow package?
    If not, I'd expect this to be spliced in. And if that's the case, I'm going to expect someone scotch-lok'd into wires, and as is inevitable with scotch-lok style wire-manglers, there's one or more compromised wires.
  7. Aug 25, 2023 at 7:11 AM
    My "tow package" was me adding a V5 rated hitch and the Curt wiring adapter plugged in between the rear harness plug to add the 4 flat. There is not a way that I know of to just splice into the wiring on these, an adapter is needed. Added a 7 pin round plug at a later date for trailer brake controller, had a buddy at a shop do it.
    shifty`[QUOTED] likes this.
  8. Aug 25, 2023 at 7:41 AM
    Ah yeah, I've seen those. If that's what OP is doing, I'd be pulled off the harness and testing continuity of the wires inside the adapter harness with a DMM, then.
  9. Aug 25, 2023 at 11:35 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    They started offering optional tow packages on the 2003 MY(V8 only), according to the brochures.
  10. Aug 25, 2023 at 12:48 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
