No Tow Mirrors
Discussion in 'Towing & Hauling' started by awq735, May 2, 2019.
  1. May 2, 2019 at 5:19 PM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    How many of you tow a travel trailer without tow mirrors? I'm about to pick up my 26 ft. Travel trailer on Monday and was wondering if its doable without tow mirrors. For those of you who put aftermarket tow mirrors on, what brand did you go with and what are your thoughts on them? Durability, fit and finish, eom quality, and what not.
    Thanks,
    Q
    Mountun Goat likes this.
  2. May 2, 2019 at 5:24 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You’re going to want tow mirrors, either the OEM style, or clip-on extension tow mirrors at minimum.
  3. May 3, 2019 at 12:49 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    What he said! I went down to a 23ft TT and did not have tow mirrors. My first time out and I quickly realized they are a must. It's funny cuz I could not tell when passing a big rig when my tail end was past him, kept waiting for him to flash his lights at me so I could get over. I am pretty damn good towing my 24ft Deckboat, but the TT is just too tall and wide to try and see around at all. Needless to say, I purchased a set of OEM tow mirrors as soon as I got home. Not to mention backing up is futile without them. Bottom line it's not worth the risk not to have them.
    ColoradoTJ, landphil and Watt maker like this.
  4. May 3, 2019 at 1:02 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    They’re 100% necessary, especially for backing up. Etrailer.com has clip on extenders you can purchase while you save up for OEM tow mirrors...I’ve used them on a Jeep and they work well. Couldn’t be happier with my oem tow mirrors on tundra, aftermarket seem to shake at speeds...
    ColoradoTJ and landphil like this.
  5. May 3, 2019 at 1:18 PM
    awq735
    Anthony
    Ohio
    Do they make oem that work with blind spot monitoring? I've seen several threads that mention that the do not
  6. May 3, 2019 at 1:19 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Depends on the width of your TT, I had huge blind spots. You can get clip ons but they shake and if you don't mind removing them all the time, not nice looking when not towing. OEM tow mirrors (and others I think) give you signal markers that work even if you didn't have that function before. These extend out. The smaller lower mirror is also great pointed at my rear tires, I can see before I curb rash.
    ManoTundra, 4x4_Angel and WFD473 like this.
  7. May 3, 2019 at 1:24 PM
    Jrharvey02
    I don’t believe they allow you to keep that function (a reason to go w/ the extenders, if it’s that important to you). I lost my mirror memory function and had to wire up the lower DRL amber light as the platinum isn’t wired for it.
  8. May 3, 2019 at 1:26 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
  9. May 3, 2019 at 1:32 PM
    Jrharvey02
  10. May 3, 2019 at 1:37 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    fyi, to change out the mirror, remove the door panel, remove the sail cover, and basically unclip harness, clip the new one, 3 bolts. Easy peasy.
    SpooledReel and Black Wolf like this.
  11. May 3, 2019 at 2:18 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    My 5th wheel is only 7' wide and after the first trip I replaced the mirrors immediately. My truck came with blind spot monitoring but didn't come with turn signals in the mirror. The Trail Ridge mirror has both and work on my truck.
  12. May 3, 2019 at 2:44 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I can’t pull anything without tow mirrors. Just plain unsafe. I bought Amazon tow mirrors and are happy with them after a year of use :)
    Black Wolf likes this.
  13. May 3, 2019 at 2:51 PM
    Jrharvey02
    Forgot to mention that PITA plastic rivet that holds the mirror on once the 3 nuts are removed. You need to squeeze it from two sides (needle nose) and pull away from truck, kinda a 3 handed job.
  14. May 3, 2019 at 2:55 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Dont have a link know but new camper was prewired for and I installed a anytime/backup camera on our 5thwheel. They work very well on the road and at the campsite.
  15. May 3, 2019 at 3:17 PM
    awq735
    Anthony
    Ohio
    Good to know. Do the mirrors have any vibration issues at highway speeds?
    What brand did you go with.
    Ive got my eyes on these currently:
    https://www.1aauto.com/2007-18-toyo...3sLLdxDjpikbbt0O1ArRXKnIVVPdPaMRoCFCcQAvD_BwE
  16. May 3, 2019 at 3:20 PM
    awq735
    Anthony
    Ohio
    Ir looks like ours comes prewired, but I have no idea how it hooks up to the truck or what kind if camera we need to get for it to work.
  17. May 3, 2019 at 4:31 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    They vibrate more than my smaller OEM mirrors but less than the factory towing mirrors on a Dodge Ram and a Ford 450 I once owned. The slight vibration is a non issue to me.
  18. May 3, 2019 at 4:34 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I also have this Furrion, it just needs a power source, like tapping the existing light. So you turn on your truck's DRL and your tow connector delivers power to the camera.
  19. May 3, 2019 at 4:35 PM
    awq735
    Anthony
    Ohio
    My drivers side mirror on my last truck(2010 F150) would vibrate slightly over bumps and if I had the stereo up loud, but the passanger side was rock steady.
    Thanks for the input. I'll stick with my stock mirrors to bring the camper home at first. I have already primed the wife into thinking that they will be purchased if(when) needed!
    KMG[QUOTED] and JoshuaA like this.
  20. May 4, 2019 at 4:54 AM
    Nm6300'asl
    2022 DC SR5 4x4
    Ours is the furrion as posted above. With the "anytime/backup" camera all I have to do is turn on trucks running lights to power the camera. With the camera and stock mirrors I can see everything.
    JoshuaA likes this.
  21. May 4, 2019 at 7:20 AM
    Creatures 1982
    Creatures 1982 New Member
    2017 SR5
    Just towed my camper yesterday love my tow mirrors
    0F1AEF09-90B8-4BE3-A830-4B3216947420.jpg OP
    They are a must the stock mirrors are to short.
    JoshuaA and KMG like this.
  22. May 8, 2019 at 2:57 AM
    awq735
    Anthony
    Ohio
    If anyone was waiting on the Trail ridge tow mirrors with BSM from 1aauto.com, they are back in stock. I submitted my email address for them to notify me when they were back in stock. Since I am an impatient person, and hadn't received an email yet, I have been checking their website multiple times a day. As of this morning, they were showing as in stock. Mine should arrive this friday, just in time to put them on this weekend!
  23. May 8, 2019 at 4:37 AM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    You won't be disappointed. I have them and pulled my TT (24') once forgetting to pull them out... No good. Huge difference. The info above is almost all spot on (pulling & backing!). Have had 2 sets of TR mirrors from A1 and they didn't vibrate at all. BSM still works great and the turn signals and marker lights are just a bonus really.
    Also that plastic center piece in middle is trash (you'll see it when you pull stock mirrors) IMO you don't need to reinstall that on the TR mirrors, mine are rock solid without the huge headache of that black plastic center clip.
  24. May 8, 2019 at 8:10 AM
    awq735
    Anthony
    Ohio
    Good to know, thanks for the info.
  25. May 8, 2019 at 8:46 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Put OE tow mirrors on my fathers limited. BSM, and RPA stopped working. But, turn signals on mirror work.
    Also, look into an observation camera not the backup camera if you look at Furrion. The observation camera has a stronger signal, so it has less interference when used full time while driving.
  26. May 8, 2019 at 9:16 AM
    awq735
    Anthony
    Ohio
    Our camper came prewired for a furrion so all I had to do was buy the camera and pop it in... It works like a champ...in my driveway at least.
    Nm6300'asl likes this.
  27. May 8, 2019 at 9:47 AM
    15whtrd
    15whtrd Mr. Blonde
    This is one reason why I have been looking at 7 foot wide travel trailers. Not ready to buy at the moment but the fact that they are narrower so I am less likely to need tow mirrors, plus it kind of needs to be 7 feet wide to fit in the spot of my driveway that I want.
  28. May 8, 2019 at 11:26 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
  29. May 8, 2019 at 11:42 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Right now I have some of the clip on ones that I had when I used my wife's Navigator to tow our TT. I just have not had a chance to order a set of tow mirrors to install on my Tundra. They are on my short list of whats needed next. To me, Toyota should sell all Tundra's with tow mirrors and have the smaller ones as options for people that don't like the big tow mirror.
    aircraft_electrician likes this.
  30. May 8, 2019 at 2:48 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Agreed, tow package should come with tow mirrors. I think they are only like a $55 option from the factory, afterwards they stick it to us at $400+ and were installing.
    mlucas555[QUOTED] likes this.
