No response on gas peddle
Discussion in '1st Gen Tundras (2000-2006)' started by mdkkisri, Jun 13, 2020.
  1. Jun 13, 2020 at 8:48 AM
    mdkkisri
    mdkkisri [OP] New Member
    Bo
    2005 tundra sr5 v8 4.7L
    I have a 2005 tundra sr5 v8, owned it for 15 yr, love my truck, never give any problems until now. No response on gas peddle. Got code p2118 , trottle actuator motor. I thought the motor was bad and not responsive so I changed the trottle body and relearn the idle ,but still no response on the peddle. Check engine light is on and very rough idle and it jerk whe I put it drive. I tried resetting the computer by unpluging the negative battery cable,, erase current and pending codes,, nothing seems to work.Where do go from here can any help.
  2. Jun 13, 2020 at 9:24 AM
    Sundown5oh
    Sundown5oh New Member
    2008 SR5
    Have you checked the fuses?
  3. Jun 13, 2020 at 9:24 AM
    mdkkisri
    Bo
    I have
  4. Jun 13, 2020 at 9:28 AM
    Sundown5oh
    2008 SR5
    I assume the ECTS fuse is good then. If the hot post on the battery gets grounded that's typically the first fuse to go which in turn throws that code and puts it in limp mode.
  5. Jun 13, 2020 at 9:31 AM
    mdkkisri
    Bo
    I checked all leads on battery terminals and wiring harness.
  6. Jun 13, 2020 at 5:57 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Take a look around the pedal, the switch may have come dislodged or faulty
  7. Jun 14, 2020 at 12:39 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    typically the newer throttles like your 05 have, its rare for the motors to go bad. its usually the pedal (also rare) or wiring.
