No power to the 12 V auxiliary seven pin trailer connecter
Discussion in 'New Member Introductions' started by Oalqadan, May 31, 2021.
  1. May 31, 2021 at 3:26 PM
    Oalqadan
    Oalqadan [OP] New Member
    2008 black tundra sr5 trd package
    I recently purchased a new 16 foot enclosed trailer that has a Dome light inside, it’s never work connected to my 2008 Toyota tundra SR5 with factory towing package. I recently connected it to my friends at F250 and the light work after looking into it more I found no power coming to the black 12 V auxiliary power cable on the seven pin connector. Any suggestions
  2. May 31, 2021 at 3:28 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Is it maybe hooked on the ignition power? Have you checked the light with the truck running?
  3. May 31, 2021 at 3:29 PM
    Oalqadan
    Yes I have, also all of the other pins work fine including the trailer brakes
  4. May 31, 2021 at 3:30 PM
    Oalqadan
    I think it may be a fuse issue but I can not find the correct fuse.
  5. May 31, 2021 at 3:39 PM
    Shanet421
    San Diego,CA
  6. May 31, 2021 at 3:53 PM
    Oalqadan
    I check all The fuses that are labelled tow and I found nothing blown
  7. May 31, 2021 at 6:51 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Jun 1, 2021 at 12:28 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska, good luck with your problem. You are sure to find your answer here on this site somewhere.
  9. Jun 1, 2021 at 1:18 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
