No power to interior fuse box
Discussion in '1st Gen Tundras (2000-2006)' started by GREGHER79, Mar 18, 2020.
  1. Mar 18, 2020 at 5:40 AM
    GREGHER79
    GREGHER79 [OP] New Member
    Greg
    2006 Toyota Tundra
    None
    I have no power to my interior fuse box. Please help. I've checked all fuses
  2. Mar 18, 2020 at 6:00 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I'd check the main fuses under the hood next.. Did you recently jump start the truck, or change the battery?
    TTund16 and bmf4069 like this.
  3. Mar 18, 2020 at 6:12 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Were you doing any work on your truck just before you discovered this ?
    How did you check for a no voltage condition to your interior fuse box ?
  4. Mar 18, 2020 at 9:13 PM
    GREGHER79
    Greg
    2006 Toyota Tundra
    None
    Yes, i changed the throttle body out. I think the battery got hooked up backwards fir just a second. Could that have blown a fuse that i don't know about?
  5. Mar 19, 2020 at 1:47 AM
    TTund16
    TTund16 New Member
    Most likely a blown fuse ... One of the big ones may be 80+ amps.
    it can also damage the battery and potentially some electronics depending on the car and the age ...
    Check the battery for any leaks.
    most likely and hopefully it's just a fuse.
  6. Mar 19, 2020 at 3:18 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Unfortunately even a second let's the ztttt's out. I would be looking in the engine bay fuse boxes for a 140 or 100 amp ALT fuse as a possibility. I would also suggest putting a little more info in your profile for your 2006. Is it an AC or DC, Reg...etc. I'll attach a 2005 AC FSM flow chart that should give you somewhat of an idea.
  7. Apr 8, 2020 at 5:33 PM
    GREGHER79
    Greg
    2006 Toyota Tundra
    None
    Replaced battery and checked 80 amp fuses and still no brake lights, tail lights, reverse lights, and no dash lights. Any other suggestions? Thanks for the other suggestion.
  8. Apr 8, 2020 at 11:08 PM
    TTund16
    TTund16 New Member
    How many fuses did you check? Did you check all high amp fuses?
    @BubbaW is showing some 100A & 140A in his post.
    also there are 2 fuse boxes in case you didn't know. My guess is the inside cabin fuses are the secondary fuses (low amps) but i've never paid detailed attention as I rarely burn a fuse.
