No power to fuel control module
Discussion in '2nd Gen Tundras (2007-2013)' started by Truck4, Nov 5, 2023.
  1. Nov 5, 2023 at 10:32 AM
    Truck4
    Truck4 [OP] New Member
    Tom
    2007 Limited CrewMax
    Hi all, no gas coming from the fuel pump. I am not getting any power to the blue wire going to the fuel pump control module. All fuses are good as well as relays. Any ideas would help. Truck ran Sunday nothing on Monday morning. It will stumble at times but dies right out. Good battery
  2. Nov 5, 2023 at 10:38 AM
    have you checked the fuel pump resister?
    Live in the engine bay near the brake booster I believe.
  3. Nov 10, 2023 at 6:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Did you try to bypass the fuel control module? Take power before FCM straight to fuel pump. Blue is positive and red neg. The FCM could be at fault but you can replace or bypass it.
    AZBoatHauler likes this.
  4. Nov 10, 2023 at 10:47 PM
    AZBoatHauler
    So.Arizona
  5. Nov 11, 2023 at 6:41 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    This is my life. I know the problem, I have no time to address the issue
    AZBoatHauler[QUOTED] likes this.
