No oil pressure
Discussion in '1st Gen Tundras (2000-2006)' started by Texmci, Jan 19, 2023.
  1. Jan 19, 2023 at 11:39 AM
    Texmci
    Texmci [OP] New Member
    Robert
    2005 blue Tundra
    I have no oil pressure on my 2005 Tundra crewmax. What could be the reason for this
  2. Jan 19, 2023 at 11:48 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Some details are needed.
    Aerindel likes this.
  3. Jan 19, 2023 at 12:00 PM
    Texmci
    Robert
    2005 blue Tundra
    What details do you need
  4. Jan 19, 2023 at 12:00 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Check oil level and report back. If good, I would expect issue with oil pump, fuse to it (if one exists) or just a bad gauge needle (or sensor to it).
    Not sure how to check it's actually running and working. Someone else here could address that.
    Aerindel and AZBoatHauler like this.
  5. Jan 19, 2023 at 1:08 PM
    Casper421
    In the woods
    06 DC
    Does it have oil?
    bmf4069 and Jack McCarthy like this.
  6. Jan 19, 2023 at 1:21 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Is the engine running? :D At what RPM?
  7. Jan 19, 2023 at 1:38 PM
    Jack McCarthy
    Bill
    North of Boston
    <OP quietly exits forum realizing no oil is present>
  8. Jan 19, 2023 at 1:49 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If proper amount of oil, the issue could be Oil Pressure Sw, Oil Indicator Gauge on Combination Meter or it's circuitry.
    If you have a VOM(volt ohm meter), check the Oil Pressure Sw down by the Oil Filter according to 2005 FSM.
    shifty` and Jack McCarthy like this.
  9. Jan 19, 2023 at 3:26 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Is it just your guage reading low? They run low normally.
    Jack McCarthy likes this.
  10. Jan 19, 2023 at 3:36 PM
    On older trucks that may be true, but on the '05-'06 it definitely rides closer to midway.
    Casper421 and bmf4069[QUOTED] like this.
  11. Jan 19, 2023 at 3:37 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Oooohh. You guys and your fancy vvt-i.
  12. Jan 19, 2023 at 3:45 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    :facepalm:
    Casper421, Jack McCarthy and HBTundra like this.
  13. Jan 19, 2023 at 4:53 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Mine always rides 1/4 until on throttle. Then half
    Aerindel and HBTundra like this.
  14. Jan 19, 2023 at 5:33 PM
    I'd hafta check mine, pretty sure at cold start it sits around the 1/3 mark, then slowly rises up to that spot.
  15. Jan 19, 2023 at 5:41 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Ground out your connection to your oil pressure sensor and see if your gauge pegs.
  16. Jan 19, 2023 at 5:59 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    :yay:
