No low beams
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ellie, Apr 8, 2021.
  1. Apr 8, 2021 at 4:00 PM
    Ellie
    Ellie [OP] New Member
    Ellie
    2020 tundra cm
    Lights / bar. /4 in lift / wheels and tires. Added center charger and got rid of interior chrome.
    Hi everyone. I have a 2020 tundra crewmax and I have no low beam headlights. High beams work as well as all the other lights I have check all fuses and relays any help would be appreciated
  2. Apr 8, 2021 at 4:10 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Warranty work at stealership
  3. Apr 8, 2021 at 4:14 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Was it just went out or were you doing something?
  4. Apr 8, 2021 at 4:15 PM
    blackdemon_tt
    Check grounds by driver side headlight
  5. Apr 8, 2021 at 4:26 PM
    Ellie
    Ellie
    2020 tundra cm
    Didn’t do anything to the headlights. I went to go to work and they just didn’t work I added a 4 in ready lift 2.0 fox suspension, method wheels and 35 in tires. I also put in a light bar in the bottom grill but that is wired just to battery and has its own switch. Also I installed rock light but they are not wired in yet.
  6. Apr 8, 2021 at 7:05 PM
    I bet it’s a cross connection somewhere. Re check all the wires from after market lights
    Black Wolf likes this.
