No local Toyota Dealer - Need bolt information
Discussion in '2.5 Gen Tundras (2014-2021)' started by Linuxmale, Oct 27, 2020.
  1. Oct 27, 2020 at 1:12 PM
    Linuxmale
    Linuxmale [OP] 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    I tried O'Rielly and they didn't have anything listed for the 14mm bolts on my 2018 Tundra. Would somebody have the size? I got my Dirty Deeds group buy muffler!
    I know it's a 2018 but I started last night and I have a feeling I'm going to have to cut some bolts. :-(
  2. Oct 27, 2020 at 2:12 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    What're you trying to do? Install a new muffler or a catback?! Get some PB Blaster and let it sit for a night...or 1:1 brake fluid:acetone is even better...wrench that sh!t off and throw the new stuff on! Or go to Ace Hardware for your hardware...or any hardware store...every town has one...you got this...it's just an exhaust update! Don't over think it...have the right tools and you got this done by the day's end!
  3. Oct 27, 2020 at 5:29 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Whoa!! Hold on!
    I literally just did that upgrade on mine last night. You should be fine just spraying them with any penetrant lube and then give ‘em hell.
    I used ratcheting wrenches, which are a little short, so if they’re a bit stuck, use a longer handled socket wrench. They will crack free and then it’s easy.
    My ‘18 has 44k on it and they just weren’t very frozen.
    Good luck- and you’re gonna LOVE that sound!
    HulkSmurf14 likes this.
  4. Oct 28, 2020 at 7:53 AM
    Linuxmale
    Yeah, I did pbblaster overnight but I rounded one of the bolts off. You’re right. I was overthinking it.
    It’s the whole cat back standard system from Dirty Deeds. So once I get one bolt out I’ll go get some new ones from ACE.
  5. Oct 28, 2020 at 8:10 AM
    SouthWestGA
    SouthWestGA New Member
    I found bolts at my local Home Depot
    M10-1.25-35mm flange Head bolts
    I used 4 of them when I installed my DD exhaust
    To get my stock bolts off,I had to hammer a smaller socket onto 1 of them and use a breaker bar with a length of pipe to bust it loose
    I anti seized the heck out of the new bolts when I installed them
  6. Oct 29, 2020 at 6:20 AM
    Linuxmale
    Thanks!
    Now I can pick them up and be done tonight.
