No light from one of my headlamps
Discussion in '1st Gen Tundras (2000-2006)' started by Undaunted, Nov 19, 2024.
  1. Nov 19, 2024 at 1:33 PM
    Undaunted
    Undaunted [OP] New Member
    Hello to everyone! I am the owner of a 2006 Toyota Tundra, 4.7L Limited 4 door crew cab. I am also a new member and therefore this is my first post.
    My question - Is it rare for the high beam, low beam, and daytime running light to all stop operating at the same time in the same headlamp bulb? Or should my issue be a connection or something else?
  2. Nov 19, 2024 at 1:36 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Check the obvious first. The bulb. Always replace bulbs in pairs. However, no info on how long you've owned the truck, so I have to assume that these are the original headlight assemblies. If not, then there could be some wiring shenanigans.
  3. Nov 19, 2024 at 3:21 PM
    Undaunted
    Thanks ATBAV8!
    I ordered two (2) Osram replacement bulbs before posting just in case it is the bulb. No store, dealer nor generic parts store, stock the 64193 (9003) bulbs in my area.
    I will troubleshoot shoot it further tomorrow and post an update when I locate and resolve the issue.
    ATBAV8 likes this.
  4. Nov 19, 2024 at 4:58 PM
    shifty` I'm having daydreams about night things
    Aren't the left and right headlight fused independently? I swear these are the two fuses in the pic below.
    See this page for your fusebox layout, search for "headlight": https://www.startmycar.com/us/toyota/tundra/info/fusebox/2006/ver-double__cab__models
    This thread may be interesting too: https://www.tundras.com/threads/2006-headlights-not-turning-on.150871/
    ATBAV8 likes this.
  5. Nov 19, 2024 at 8:09 PM
    Undaunted
    Thanks shifty! I’ll definitely check out the links you provided.
  6. Nov 24, 2024 at 7:53 PM
    Undaunted
    ATBAV8 & shifty
    Update:
    Replaced the non-illuminating bulb over the weekend and that solved the problem. I’ll replaced the other one tomorrow so that both will be Osrams.
    Thanks to both of you!
    ATBAV8, w666 and shifty` like this.
