No hot air. Will replacing my thermostat fix this problem?
Discussion in '1st Gen Tundras (2000-2006)' started by BurgundyTundy, Nov 13, 2018.
  1. Nov 13, 2018 at 7:44 AM
    BurgundyTundy
    BurgundyTundy [OP] New Member
    Rob
    2002 Tundra SR5
    As the weather gets cold I switched from AC to heat but it only blows cold air.
    I recently got a new radiator and transmission cooling pump. During this they flushed the radiator.
    I will be replacing the thermostat soon, but I've read that there may be another problem causing this.
    I'm wondering what the problem is and if any tutorials on how to fix them are out there.
  2. Nov 13, 2018 at 7:47 AM
    Hey Rob. You may have a heater core issue.
    Are you handy with basic tools?
  3. Nov 13, 2018 at 7:50 AM
    BurgundyTundy
    Rob
    2002 Tundra SR5
    Yes I am. I tend to do most projects with the supervision of my dad because I'm still young.
    because_wumbo-truck likes this.
  4. Nov 13, 2018 at 8:05 AM
    Great. Is your motor coming up to operating temperature?
    Remove your heater core hoses, drain coolant, flush out.
    Use some CLR (you can get it cheap at Walmart), fill up heater core and tie up hoses and let it sit for a bit. Drain and flush really good. Hook hoses back up, top off coolant after you start truck.
  5. Nov 13, 2018 at 8:13 AM
    BurgundyTundy
    Rob
    2002 Tundra SR5
    My truck is heating up correctly and running good for these temps.
    Ill talk to my dad and we will try it out. Thanks.
    ColoradoTJ likes this.
