No Hissing sound when opening the gas cap
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTund16, Apr 17, 2017.
  1. Apr 17, 2017 at 5:44 AM
    TTund16
    TTund16 [OP] New Member
    Does your Tundra make a whooshing or hissing sound when you open the gas cap?
    My 97 Tacoma does that (very long whooshing sound most of the time) and just curious if other Tundra's do it or not. Mine doesn't! I have another old car that makes the same sound.
    The car runs great but I like to find non-existing problems :)
    Thanks
  2. Apr 17, 2017 at 5:56 AM
    As in air pressure? No.
  3. Apr 17, 2017 at 5:58 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Yup... It's not supposed to... That's what the evap system is for
    TTund16[OP], Noodle, Cat3ILS and 2 others like this.
  4. Apr 17, 2017 at 6:01 AM
    TTund16
    like there is pressure or vacuum in there and when u open the cap it makes a long hissing sound ...
    I have 2 other cars that do make that sound every time I am getting gas and i am used to it so I maybe comparing new technology with older cars.
    ok thanks, I just saw the evap system post.
  5. Apr 17, 2017 at 6:11 AM
    Don't over fill the tank either.
    TTund16[OP] and 15whtrd like this.
  6. Apr 17, 2017 at 7:39 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Mine does. If I get close enough, I think it's saying "thirsssssssty".
    DVYota, Law323, gosolo and 5 others like this.
  7. Apr 17, 2017 at 9:30 AM
    TheBeast The Beach
  8. Apr 17, 2017 at 10:48 PM
    TTund16
    do you mean leave some room for air? is it bad to fill it to the rim?
  9. Apr 17, 2017 at 11:23 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep, pull the filler nozzle and quit the first time it clicks off.
    TTund16[OP] and NewImprovedRon like this.
  10. Apr 18, 2017 at 9:48 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If you go beyond the first click, there's a chance that when the fuel expands, it will flood the evaporation system with raw fuel and cause issues. The system is designed for fuel vapor and not liquid fuel. What sorts of issues may occur, I'm not sure, but maybe someone who has had them or understands it better can share.
  11. Apr 18, 2017 at 9:58 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I do not have that sounds on mine.
  12. Apr 18, 2017 at 10:07 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'll try to check mine today when I fuel for my early run to Denver tommorow. Data gathering. :cool:
