no factory brake control harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by anthony1958, Dec 7, 2024.
  1. Dec 7, 2024 at 10:59 AM
    anthony1958
    anthony1958 [OP] New Member
    anthony
    2017 tundra 4.6
    i have a prodigy3 controller and while poking around under the dash i found that my SR does not have a harness.i can hook up power thru a line with a inline fuse . the only hangup is where to attach the red line to brake pedal switch. i am not sure which to use.there is a brownish line with a stripe that i think is hot but the red,the black, and the blue are all real thin wires compared to wire on the controller . constructive advice appreciated. thank you
  2. Dec 7, 2024 at 11:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Yes, SR does not have it. It can be wired up, check etrailer website, they will often have install vids. Or, Im sure Youtube has some where folks added controllers.
    And lastly, if you search this site (search box up top)....there may already be a write up with all the details on the install.
    anthony1958[OP] likes this.
  3. Dec 7, 2024 at 11:56 AM
    frichco228
  4. Dec 7, 2024 at 3:29 PM
    anthony1958
    anthony
    2017 tundra 4.6
    thanks very much,i will check it out
