No crank. No start.
Discussion in '1st Gen Tundras (2000-2006)' started by Anjitzu77, May 2, 2024.
  1. May 2, 2024 at 7:21 PM
    Anjitzu77
    Anjitzu77 [OP] New Member
    Angie
    2006 Toyota Tundra double cab
    So, all of a sudden my truck would not start. It did crank at first but now, no crank no start. Battery cables cleaned. New starter put in. Still nothing. Fuses checked. Ground wire maybe?
  2. May 2, 2024 at 7:23 PM
    shifty` In South Dakota Trouble ain't hard to find
    Please tell me you tested your battery and checked the starter relay before going through all the pain and suffering and expense of changing the starter. It's almost never the starter.
    Also, did your truck ever have an aftermarket alarm installed, up under the driver's side of the dash? Do you know if your double cab is one that was equipped with immobilizer, i.e. it needs a chipped key? Did you try another factory key?
    Bob and FrenchToasty like this.
  3. May 2, 2024 at 7:26 PM
    Anjitzu77
    Angie
    Even though I insisted that it wasn't the starter since it cranked, no one listened and changed it. It's a double cab. No aftermarket alarm. We do have 2 keys. They said they checked the relay.
  4. May 3, 2024 at 7:43 AM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    Nuetral safety switch?
  5. May 3, 2024 at 7:45 AM
    Another stupid question, but will it turn over when you throw jumper cables on it from another known-working vehicle? (to both - and + terminals)
    Got a picture of the engine bay, just so we can visually see what you're looking at? Taken from high over the middle, so we can visually check all grounds and whatnot.
  6. May 3, 2024 at 4:48 PM
    Anjitzu77
    Angie
    We tried that originally. Haven't tried the factory key yet. Waiting for my step dad to bring it over.
  7. May 3, 2024 at 4:51 PM
    Anjitzu77
    Angie
    I'm a single mom and share custody with my ex. If I don't have a working vehicle, I can't have him because I can't get him back and forth to school. I'm so stressed. After reading some threads, you guys seem really knowledgeable so I'm hoping for a miracle!! I will try anything. So please keep throwing it ideas for me to check. I'm so grateful for you guys
  8. May 3, 2024 at 4:53 PM
    Anjitzu77
    Angie
    And we did try to start it in other gears but nothing.
    2mchfun likes this.
  9. May 3, 2024 at 4:54 PM
    2mchfun
    If you turn on the key can you shift out of park? If so, have you tried shifting into gear and then back to park with the key on?
  10. May 3, 2024 at 4:59 PM
    2mchfun
    Does the steering column telescope in this truck? Sometimes wires break from frequent movement when the column is extending and retracting.
  11. May 3, 2024 at 5:01 PM
    I'm just curious if you get any turnover by jumping the starter relay. (basically bypass the relay to force power to the starter)
    I'd also be curious to test for power at the starter itself, like maybe the starter wires got nicked or the ground is crusty? Mice love nesting up under there, maybe they chewed a starter wire and the shop missed it?!
    2mchfun likes this.
  12. May 3, 2024 at 5:05 PM
    2mchfun
    Make sure in park before jumping relay!
    shifty` likes this.
  13. May 3, 2024 at 5:16 PM
    2mchfun
    You can watch Youtube to see how to bypass relays
    shifty` likes this.
  14. May 3, 2024 at 5:17 PM
    To his point ^^ this vid is for a 2000 Tundra, so won't be identical to yours, but you get the idea. If you look inside your fuse/relay cover in the engine bay, you can tell which of yours exaclty is start relay.
    2mchfun likes this.
  15. May 24, 2024 at 9:33 AM
    VWmanwithTundra
    VWmanwithTundra New Member
    Kevin
    2002 tundra access cab
    Work in progress lol
    we gonna help this person?
  16. May 24, 2024 at 9:39 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    You're the 20 year mechanic. Get busy.
    shifty` likes this.
  17. May 24, 2024 at 10:40 AM
    Anjitzu77
    Angie
    I really appreciate all you guys! So, to catch you up ... So far their mechanic has replaced the starter, fuel pump, ignition switch. Lol. There wasn't any codes popping up until after all that. Now it says 7 codes!!
  18. May 24, 2024 at 10:47 AM
    2mchfun
    Wholly smokes! Does it start?
