No Crank, no start....try again and it fires right up??
Discussion in '2nd Gen Tundras (2007-2013)' started by leechlake, Jun 3, 2019.
  1. Jun 3, 2019 at 8:04 AM
    leechlake
    leechlake [OP] New Member
    2008 Tundra Supercrew
    My '08 5.7 supercrew just started with this issue. Drive around no problem, go to start vehicle and it won't crank, nothing. Dash lights up, plenty of battery power. Try again later and it starts. Next time it won't crank and I don't even have dash lights. Check battery power with multimeter, all good, get back in and it starts. Last night, no crank, no dash lights, couldn't even lock the doors with the key fob. This morning I walk out and it fires right up. What's going on?
  2. Jun 3, 2019 at 8:08 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Bad ground??
    Try cleaning battery terminals, check where negative battery cables go, clean that too.
    15whtrd and TokerJoker like this.
  3. Jun 3, 2019 at 8:12 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Is there an aftermarket alarm? I had one give me similar random issues on a past vehicle.
    15whtrd likes this.
  4. Jun 3, 2019 at 8:14 AM
    Have you tried a different key?
    NewImprovedRon and TokerJoker like this.
  5. Jun 3, 2019 at 8:19 AM
    leechlake
    No alarm on it, have tried using a different key
    TokerJoker likes this.
  6. Jun 3, 2019 at 8:21 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Also insure battery terminal connectors are tight.
    NewImprovedRon likes this.
  7. Jun 3, 2019 at 8:21 AM
    How old is your battery? It’s almost acting like it’s not reading it in park for a second. My wife’s Jeep had that issue years ago.
  8. Jun 3, 2019 at 8:22 AM
    leechlake
    They don't budge
  9. Jun 3, 2019 at 8:24 AM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    I wondered then could you have a faulty ignition switch in your column?
    Black@Blue19 and Trooper2 like this.
  10. Jun 3, 2019 at 8:36 AM
    Trooper2
    JR
    TokerJoker[QUOTED] likes this.
  11. Jun 3, 2019 at 8:47 AM
    leechlake
    I did have a new muffler installed 6 days prior to this occurring after no issues for 7 years. Could some type of emissions crap have been altered leading to this issue?
  12. Jun 3, 2019 at 8:54 AM
    Trooper2
    JR
    Not sure or how it would. I would get under there and look around for loose or damaged wiring/harnesses.
    But if only muffler it should not be near pertinent wires. Would only think O2 sensor involved, if issue then just a running code not affecting starting.
  13. Jun 3, 2019 at 9:02 AM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Could have loosened/ damaged the wires/ harness/ connector leading to the starter.
    Trooper2[QUOTED] likes this.
  14. Jun 3, 2019 at 10:58 AM
    leechlake
    Stopped home over lunch, starts every time I try it now, can't get it to not start? Will crawl around after work if see if I can follow wire harness and look. Would a loose wire to the starter cause me to have no power to the dash though before even trying to crank it? I can understand wiring issues at the starter preventing starting, but not being able to lock the doors with the key fob?
  15. Jun 3, 2019 at 11:10 AM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    I would check the ground wire to your engine block. When the engine is hot the ground cable end is expanded and makes a good ground, when cools it may not make the ground connection. Had this happen once on my old truck.
  16. Jun 3, 2019 at 11:24 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Sounds like your battery, they’re like gremlins when dying and hot/cold really effects how they perform. What’s the voltage reading you got? How old is battery?
  17. Jun 3, 2019 at 12:59 PM
    leechlake
    12.5 volts, if it doesn't start, it's not because it's cranking hard, it won't crank at all. Next time I try it fires up like there's never been an issue.
  18. Jun 3, 2019 at 2:28 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Starter Switch?? Something whacked in the column?
  19. Jun 3, 2019 at 3:23 PM
    SCtundra215
    SCtundra215 New Member
    Jmart
    Sc 2nd gen Trd
    Supercharged 5.7L Trd big brakes Trd sway bars Trd exhaust Amp power steps Decked bed box 3.5” lift 35” kumho m/t 20” -44 rockstar blk/machine 811 wheels
    I have had this issue and later got a crankshaft position sensor code. It’s easily gotten to (aka not under the skid plate) under the truck, I popped it out and wipped it off a little and put back (has a little cover, might be 10mm) and it was fine for a while. But the symptom was exactly that, it would be no start for hours and then suddenly it would just crankover. Also no jumpstart would work either.
    leechlake[OP] and NewImprovedRon like this.
