No Audio
Discussion in 'Audio & Video' started by Tankman52, Jun 17, 2025 at 7:17 PM.
  1. Jun 17, 2025 at 7:17 PM
    Tankman52
    Tankman52 [OP] New Member
    Tuesday
    Rob G
    2008 Toyota Tundra SR5
    None
    I have a 2008 Toyota Tundra SR5 that I installed a Boss BV9358B 7in screen stereo. However, there are some issues as I have listed below.
    1. No sound
    2. The 12v constant (yellow Wire) does not power up the stereo when voltage is present unless the Red wire (12v ACC) is connected to the yellow wire. This is not correct in the instructions
    3. The remote (Blue/White Stripe) wire that provides power to signal to the remote does not work.
    4. Yellow wire which is constant power keeps the stereo on even if the ignition is off.
    5. The switch wire (ignition power) does not turn on the stereo and v/v.
    Any knowledge and suggestions are welcome!
    thanks, Rob
