No acceleration after fillip
Discussion in '2nd Gen Tundras (2007-2013)' started by kyledeb1, Mar 24, 2019.
  1. Mar 24, 2019 at 4:34 PM
    kyledeb1
    kyledeb1 [OP] New Member
    2009 Tundra
    2009. Need help. Anytime after I fill up, my truck will not accelerate for about 30 secs.
    Idle is fine, starts fine, but when I push the gas nothing happens. It can be a complete fillip or just 10 bucks. If I sit on gas for about 30 secs, it kicks in Any ideas?? Thanks
  2. Mar 24, 2019 at 4:37 PM
    TheBeast The Beach
    odd. After ea. fill up, gotta have to do with some gas capacity reset in the ECU somewhere. How is your MAF looking ? how about spark plugs ? how many miles on the truck?
    Black Wolf likes this.
  3. Mar 24, 2019 at 4:41 PM
    kyledeb1
    2009 Tundra
    Plugs changed about year ago. 130k on truck. It is strange because once it kicks in, it is fine until next trip to gas pump. MAF? Is this the mass air flow sensor you are referring to?
    TheBeast likes this.
  4. Mar 24, 2019 at 4:42 PM
    TheBeast The Beach
    yes, might be worth cleaning it. pretty straight forward. make sure you use MAF cleaner.
    kyledeb1[OP] likes this.
  5. Mar 24, 2019 at 4:43 PM
    TheBeast The Beach
    did you plug an OBD reader ? any codes ?
    try disconnecting battery too for 10 min.
    Black Wolf and kyledeb1[OP] like this.
  6. Mar 24, 2019 at 4:46 PM
    kyledeb1
    2009 Tundra
    No codes at local Auto Zone.
  7. Mar 24, 2019 at 5:17 PM
    koditten
    Kirk
    Midland of the Mitten
    This sounds live an emission system issue.
    Evaporator purge valve stuck open, making the intake a fuel rich environmente until it clears out excessive vapors?
    I know I'm gonna get flamed, but try filling, but leave the car running. If it doesn't have issues, you have narrowed down the possible problems.
  8. Mar 24, 2019 at 5:24 PM
    kyledeb1
    2009 Tundra
    I have tried to fill up with truck running and it still does it. Would that give any new information? Appreciate the help of all! Thanks
  9. Mar 24, 2019 at 5:27 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Do you top off the tank after the nozzle clicks itself off? If so I would recommend stopping that practice and don't add any gas after it clicks, that can cause issues with evap system.
  10. Mar 24, 2019 at 5:29 PM
    TheBeast The Beach
    that's another idea. how about filling up but not to the max, does it still do it ? like maybe filling up one less gallon.
  11. Mar 24, 2019 at 6:20 PM
    FXFormat
    FXFormat New Member
    Something is going on with your evap system, like fueling up is clogging up some valve and not letting it purge. Next time fill up, start the truck, then start the truck and leave the gas cap open. See if that will let the truck run, you might throw a code for P0441 but that can be turned off by pulling the battery for a few minutes.
  12. Mar 24, 2019 at 6:55 PM
    kyledeb1
    2009 Tundra
    Those are great thoughts. I am gonna give these a try and post afterward. Thanks so much!
  13. Mar 24, 2019 at 7:08 PM
    THIS^
