Nitto Terra grappler vs ridge grappler
Discussion in 'Wheels & Tires' started by The tundy, Jul 28, 2018.
  1. Jul 28, 2018 at 5:52 PM
    The tundy
    The tundy [OP] New Member
    2001 tundra limited
    Hey I have a 2001 tundra and I’m about to pull the trigger on some new wheels and tires. Im currently running terra grapplers on the truck and I’ve been very happy with them but I have been hearing great things about the ridge grappler. Basically I was wondering if any how much would a ridge grappler sacrifice in gas mileage vs a terra grappler? I spend most of my time on the road putting well over 100 miles a day on my truck most days but I do find myself every now and then where a more aggressive tire would help. Was just wondering if anyone has ever run both on their truck and what the differences were. Thank you.
  2. Jul 28, 2018 at 8:29 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    I ran terra grapplers on my 04 Tacoma and had no complaints. Did very good in the snow.
    NewImprovedRon likes this.
  3. Jul 28, 2018 at 8:42 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    The RGs are a little nosier and noticeably heavier. They're fine even on long drives though
  4. Jul 30, 2018 at 3:53 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I wouldn't think they would sacrifice too much in gas mileage if you go with the same size and they are similar in weight. The terra grapplers should be lighter though as the RG's have a bigger sidewall. I would say to plan on a 1 mpg loss and hope that you don't have that. You shouldn't have more than that, so ask yourself if you could deal with that. If so, go for them!
  5. Jul 30, 2018 at 6:04 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I have put roughly 1500 miles on my RGs. I can tell they are heavier but are actually very quiet. I have gone from 14.5 MPG to 14.4 MPG.
  6. Jul 30, 2018 at 7:51 AM
    PMG
    PMG New Member
    RG's are quiet. Doesn't hum like the others. Took it for a 5k trip with the toddlers and no complaints whatsoever.
    zcarpenter92 and JoshuaA like this.
  7. Jul 30, 2018 at 8:01 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    2015 TRD Pro CM Inferno Fast
    Just ceck out build thread in sig
    Yeah Ill have to echo what a few others have said. I had 295/70r18 G2 TGs and then went up a size to 35x12.5 RGs and the RGs are actually unexpectedly quieter. Not sure why, just my observation. Both are very capable. RGs look a bit more aggressive to me, and I liked that look. The RGs are not a true mud terrain tire, but Ive taken both TGs and RGs off road and the think the RGs are step closer to a mud terrain and even when caked in clay they would still pull my ass out of the mud.
    RGs
    TGs
  8. Jul 30, 2018 at 8:10 AM
    BROGAN
    BROGAN FNG
    Logan
    East TX
    Oh and as far as fuel economy....instead of badass off road tires you could go with a Prius. Not about miles per gallon my friends, its all about the smiles per gallon. But to attempt to answer your question, you likely will not see a difference in MPGs if you stay on the same size tire. You may see a very small loss of MPGs if you go up in size, buts way offset by the SPGs...smiles per gallon ;)
    zcarpenter92 likes this.
  9. Jul 30, 2018 at 6:49 PM
    The tundy
    2001 tundra limited
    Thanks for the replys everyone it really sounds like everyone is really happy with their RGs.
  10. Jul 30, 2018 at 6:55 PM
    The tundy
    2001 tundra limited
    I do agree smiles per gallon is more important than miles per gallon but with the amount I drive it definitely is a factor. The reason I ask is because when I bought my truck it had highway tires and when I switched to my terra grapplers that I have now I lost about 2-3 mpg on the highway same size and everything only difference is tread pattern.
    BROGAN[QUOTED] likes this.
  11. Jul 31, 2018 at 11:01 AM
    PMG
    PMG New Member
    That middle patch of the RG has lugs that are spaced closely and aids in the noise redution.
  12. Aug 4, 2018 at 11:08 AM
    The tundy
    2001 tundra limited
    Just pulled the trigger on some fuel vandal 18x9 -12 offset and Nitto ridge grapplers! Very excited to see what it’ll look like as there is nobody around my area running anything like this. I’ll send pictures when they come in and I get them on the truck
    Rica25 likes this.
  13. Aug 4, 2018 at 12:29 PM
    Rica25
    Ricardo
    Tulare
    Very quiet for the aggressive look you will like them
